Thread: On board computer question
    Aug 2011
    Ayr
    Vehicle : Insignia
    Trim : SE
    Engine : 1.8
    Year : 2010
    Default On board computer question
    Hi folks.
    Being a new owner of an 07 Vectra sri,I have a query about the on board computer and the info it shows.
    For some reason which is beyond me,when viewing the mpg, the display has a habit of showing 999.99 mpg.This does not happen all the time,but seems weird.
    Any advice would be welcome before I take the car back to the dealer I bought it from last week.
    Davie
    May 2011
    bispham, blackpool
    its when you are driving and you let off the accelerator i think its because its using no fuel to move you along whilst your foot is off the accelerator if you keep it in the same gear when your slowing down to stop instead of dropping down a gear to slow down you will notice it stays at 999.99 mpg untill you put the clutch in which means all that distance you were slowing down you didnt use any petrol
    they might be a proper saying about it but this is my interpetation
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    It is 'run-on' when you lift off the accelerator at any speed, and very little fuel is used until the ECU calculates that more fuel needs to be injected, as momentum is lost. The higher the speed/rate of momentum the longer the 'runon' lasts. I assume it is the same for both petrol and diesel engines.
    Yes, it's weird. It is much more noticeable on the facelift, due to the much larger and more-prominent central display of current mpg.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Mine does it sometimes when I coast
    Aug 2011
    Ayr
    Vehicle : Insignia
    Trim : SE
    Engine : 1.8
    Year : 2010
    Thanks guys for your input.I tried coasting on the way home from work earlier,and it did exactly as you said it would while the engine was not under load.
    Many Thanks
    Davie
    Jun 2011
    Elland
    If you set it to European units, it will show consumption in L/100km, it will show 0.0L/100km. Fuelling is shut off on the over-run, but as our units are the 'other way round, this would cause a 'divide by zero' error: something divided by nothing. It's just a software coding tweak: you're not really doing 999mpg, you're doing an infinite number of miles/gallon as no gallons are being used
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Yep as described - whenever the engine is on "over-run" - that is braking, decelerating or coasting, as this is when the injectors are turned off, and so not delivering fuel.
    Hence you are doing an infinate number of miles to the gallon.
    999.9 is the nearest value to infinity that the fuel computer can display.
    It will drop to a much lower value if you dip the clutch, or touch the accelerator pedal.
    It will do it on ALL Vauxhalls with a fuel / trip or board computer... even my 1994 Cavalier. Both petrol and diesels
  1. Board computer
    By Stewy1985 in forum Vectra C / Signum Car Chat
    Last Post: 11th February 2013, 02:23
  2. on board computer
    By skip85 in forum Engine & Drivetrain
    Last Post: 5th February 2013, 12:14
  3. board computer question
    By stret in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2013, 16:18
  4. anyone added trip computer/board computer?
    By Craig1985 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2008, 02:33
  5. board computer
    By rioni in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2008, 08:50
