Results 1 to 10 of 14
Thread: Please help lost key
    May 2011
    london
    Default Please help lost key
    My key was lost it came away from the 3 button fob i still have the fob but that is my only key is there any way that a new key can be created i dont have the code card it is a vectra 03 plate.
    On top of all that recovery service damaged the underneath of car and is now flooding oil all i did was take the kids out for the day and ended up a bad day
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    If you ring vauxhall you can pay for the key code etc
    Glasgow
    As above your local dealer parts dept will need to order you a new car pass and key then program it to your car.
    Jul 2009
    The Rift, Cardiff
    A new key or just the blade can be cut from the code but, as above, you'll need the key code from the carpass. You'll need to take the v5 document and id with your address (driving licence) to the dealers for the carpass, which usually costs around £20 and takes around 3-7 days, but they may give you the key code sooner if you explain your situation.
    If your fob still works you can get the key blade alone.
    May 2011
    london
    Great thanks for info...
    im guessing getting the keycode ordered is a lot cheaper than having someone round to take out barrel and create a key from that.
    Yes the fob works ok a bit worn but all works im pleased with that as i know they cost a fortune.
    May 2011
    london
    i been told that the immobiliser is in the blade is this correct?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by domino69 View Post
    Not sure but I wouldn't have thought so. Can you claim of the recovery people for the damage?
    May 2011
    london
    It seems the immodiliser is in the arch of the blade that clips into the fob grrrrrrr and vauxhall no longer sell these i have to get a complete new key and fob and get it programmed...
    I was told to call the recovery office on monday to sort it i hope it wont cost me anything.
    Jul 2009
    The Rift, Cardiff
    I don't think the vec has a key with the chip in the blade. On my old-style-pre-facelift key there used to be a separate chip in the fob case (small black plastic rectangle), but that was replaced by one built into the circuit board when the key was reprogrammed. The newer style flip keys also have the chip built into the circuit board iirc.
    May 2011
    london
    It seems on my stile key there is a plastic arch at top of blade that holds the immobiliser and that part clips into the fob but this type is discontinued i wander why.......maybe cause they fall apart
  1. Lost my A
    By DonnaH in forum Bodywork & Interior
    Last Post: 6th August 2012, 20:08
  2. lost key
    By Tam80 in forum Bodywork & Interior
    Last Post: 3rd December 2010, 09:11
  3. Lost Cat
    By VXR_DV in forum Comedy & Humour
    Last Post: 23rd October 2010, 10:04
  4. Lost
    By neilshaw1980 in forum The 'Off Topic' room
    Last Post: 25th January 2009, 00:08
  5. Lost
    By thegoldenbullet in forum General Chat
    Last Post: 27th March 2007, 01:54
