Thread: V6 Cdti glow plug relay
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default V6 Cdti glow plug relay
    Any one tell me which relay it is. Had management light come on before
    And got code p0382 glow plug relay malfunction
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It's a component on its own
    From memory it is located on the nearside
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Any idea where abouts mate? as I've gone in the engine bay fuse box an there's a few relays. there's 2 yellow 2 brown an a black if memory serves me correctly.
    These are the only relays a could see last night
    Regular Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    The relay is situated behind the front bumper in your drivers side...
    But, but, but... Check glowplugs with at potentiometer first...
    I had the same fault in my old v6 cdti and is came down to one faulty glowplug... The reading should be 1,0 Ohm on the glowplugs..
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    What a potentiometer?
    I have checked voltage and resistance on the ones I can get to using digital multi meter an they seem ok.
    There's 2 I couldn't easily get to so obviously I need to check them to.
    How much where the glow plugs if you font mind me asking?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Well I've found fault. Something I somehow missed when checking glow plugs other night.
    A bolt off one of brackets in engine had somehow come out and was sitting next to glowplug and obvisously creating a short to earth.
    Bolt removed an returned to it's bracket an fault clear
  1. glow plug relay
    By iwtand in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 14:25
  2. 3.0 cdti glow plug relay HELP!!
    By dshelton999 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd September 2011, 22:12
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
vauxhall vectra v6 glow plug relay
