Thread: Fog light problem but bulb okay
    Oct 2006
    Surrey
    Default Fog light problem but bulb okay
    Hopefully someone has seen this before. Rear l/h foglight doesn't work causing blub warning on dashboard. Have checked bulb and replaced with two others, have also re-seated bulb holder. I don;t have a fuse board diagram so does anyone have any ideas?
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    I had this problem when I wired up the other fog light. The black connecter was n't seated in properly but the light worked and I got the warning on the ICE. Took the conecter back out and re-seated it and AOK.
    Oct 2006
    Surrey
    Thanks for the prompt reply. Was it the rear fog light?
    Offside rear on my 06 plate estate
    Oct 2006
    Surrey
    I tired reseating but to no avail. I might try the opposite cluster when it is light tomorrow and see if that works. Could be the plastic bulb holder. Very nice Vectra estate btw - just a bit jealous!
    [Ex]Admin Duncan's Avatar
    Steveo, when you say rear l/h fog I'm assuming therefore that you've wired that one in to work? If not, then the rear l/h isn't meant to work and your bulb warning could be from a different bulb?
    Oct 2006
    Surrey
    Ah! That's because it is a UK car and I am as thick as sh!t - many thanks! Right, hmm, now wondering where on earth the warning light is coming from. Have checked all external lights and they work okay. Does it also flag up internal bulb faults?
    Feb 2006
    Guttedsville
    Check your number plate lights all work.
    Hertfordshire
    Surely when you turn the ignition on the display should tell you exactly which bulb it is ???
    Regular Member cameraman's Avatar
    Leicester
    Quote Originally Posted by Green Growler
    Only if you have the trip computer!.
  1. AFL light owners - kerb light bulb upgrade?
    By MCD in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2010, 23:09
  2. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
  3. rear brake light problem, bulb ok, please help
    By circushead in forum Electrical & ICE (including SatNav)
    Last Post: 14th May 2009, 18:29
  4. bulb problem
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 15:46
  5. Parking light check bulb light on and wont go off
    By rollercoaster63 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2008, 12:03
vectra c fog light earth issue
where is fog light earth on vectra c
