Thread: Y30DT Looses boost, clear fault code and back to normal!
    Oct 2007
    Telford
    Angry Y30DT Looses boost, clear fault code and back to normal!
    Right had my 3L V6 sri remapped by MPG, did a cracking job, boost is strong 99% of the the time and the car pulls like a train. Only problem and its happened twice since it was mapped is the boost pressure sensor fault code comes up. P0235 iirc, so with my cheapy Sealey code reader, I can clear the fault, spanner light goes out and I can carry on my way.
    Im thinking because the boost pressure has been raised could the actuator be sticking? Im not sure of the turbo set up on this engine. Is it possible for the waste gate to jam open by-passing the turbine. Reason I ask is the exhaust goes really loud, which I'm thinking is being caused because there is no silencing effect caused by turning the turbine blades. Reasonable theory?
    It's an annoying niggle thats spoiling an otherwise perfect car. Help me!!
    Oct 2007
    Telford
    Anyone help me with this please??
    Full Member Big Sig's Avatar
    Whip the boost sensor out and give it an inspection. It might just need cleaning.
    Jun 2011
    Elland
    From TIS2000:
    With trouble code P1635 not recognised:
    • The boost pressure is too low
    Effect:
    • Exhaust gas recirculation valve is switched off
    • Boost pressure control is not longer possible.
    conversely:
    • The boost pressure is too high
    Effect:
    Remedy is listed as checking high pressure (air) components for leakage - not much other useful information. However, since the EGR is also mentioned, it might be worth obtaining some live data readings whilst the car is being driven - especially if the fault is readily repeatable.
    EDIT: did they map out the EGR as well?
    If so, you might need to take the car back for a little 'tweaking' of the map to keep things 'within parameters'
    Engine : 1.9 CDTi
    Have you checked for boost leaks?
    Make sure the boost hoses are clamped nice and tight as they maybe leaking under full boost.
    Oct 2007
    Telford
    I did ask if he could map out the EGR, however he said it wasn't possible to do, so would this still cause an issue, I will check out the boost pressure sensor to see if it's diffy.
    Jun 2011
    Elland
    Quote Originally Posted by lee gsi View Post
    Yes m8, good suggestion - I have had issues with the union between the throttle body and the rigid pipe (top of engine) and with the pipe splitting as well (part on order right now!). Also the flexi pipe to which the rigid one connects to has been known to split.
    At 1500rpm, the engine makes appreciable boost, so if you can get someone to hold the revs here, you can look under the bonnet (engine cover removed) and look / listen / feel for leaks.
  1. Fault Code P0234 - Boost Pressue
    By Gazz in forum Engine & Drivetrain
    Last Post: 15th October 2012, 10:48
  2. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  3. Y30DT boost sensor?
    Last Post: 29th December 2011, 21:27
  4. MAF fault code won't clear
    By GSiFan in forum Engine & Drivetrain
    Last Post: 30th August 2010, 21:18
y30dt p1635
p0235 opel y30dt
