Thread: Spring fitters in Durham
    Regular Member GoldenWonder's Avatar
    Durham
    Default Spring fitters in Durham
    I'm considering putting a set of lowered springs on my 2006 vec 1.8 vvt - nothing drastic but maybe 30mm using one of the spring kits I've seen on LMF's website.
    Question is - what sort of figure am I looking at for a garage to fit these? I've not got the tools/room to do it myself so I'm looking for a recommendation for a garage in the Durham area?
    East Ayrshire
    Trim : SRI XP1
    Can't advise a garage but an independant could do it in under 2 hours so no more than £100 i'd guess. I've changed 2 x rear springs in half and hour. The fronts are about 1/2 hour each
    Durham
    So £300 for the whole thing is a realistic budget? I'm not after anything really over the top - just lowered a bit and to prevent the VX springs snapping!
    Then its a set of alloys...when my scratchcard comes up trumps!
    East Ayrshire
    Trim : SRI XP1
    It really depends what set-up you go for. There are several threads with different recommendations, there always is as it's a personal preference. This is the first car i've had that i won't be lowering. Sri setup on 19s is comfy enough for me. If you drop it any major amount it will get bumpy, 35mm is about ok. Shouldn't need to change your shocks at that height either as long as they're not knackered. the sri is down 20mm (i think) as standard so if you have that then it will only be another 15mm down The ones on the lmf site are good stuff. Apex/spax and eibach etc are all big names aswell as koni
    Durham
    Cheers - I think 35mm will be enough for my dodgy back!
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    If you can get hold of a set of spring compressors its a piece of cake to do yourself, plus you'll save £££ in garage fee's
    Full Member RBH's Avatar
    Jan 2008
    Central Scotland
    100 Post(s)
    Vehicle : Insignia VX Line
    Trim : SRI
    Engine : 2.0 CDTI
    Year : .....
    Get eibach pros from demon tweeks mate - 30mm drop..............£159 delivered mate
    Durham
    I gather you only need the compressors for the front set? I think a mate of mine might have some.
    I saw the Demon Tweeks ones as well - too many choices!
    East Ayrshire
    Trim : SRI XP1
    yeah, the back ones you just undo one bolt and push down the lower arm, old out new in and tighten back up
    Jan 2008
    Central Scotland
    100 Post(s)
    Trim : SRI
    Engine : 2.0 CDTI
    Year : .....
    Quote Originally Posted by GoldenWonder View Post
    eibach pro 30 mm drop - recommended by vauxhall - mines are being fitted on sunday
  1. hello from co. durham
    By Dwing007 in forum Introduce yourself.
    Last Post: 12th April 2012, 13:21
  2. any carpet fitters on here?
    By chris1804 in forum The 'Off Topic' room
    Last Post: 11th September 2010, 19:54
  3. Towbar fitters in the NW?
    By m111kan in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 8th May 2010, 19:26
  4. any windscreen fitters...
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2008, 21:31
  5. tyre fitters!
    By blr123 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd April 2006, 23:40
