Thread: Wheel/ Tyre Limitations
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Default Wheel/ Tyre Limitations
    I've just bought and fitted some 18's from a guy on Ebay. They were originally on a Vec B GSI. They looked a little flat on the fronts so i pumped them up to 38 psi. Still they looked a little flat. I had a look on the tyre and the wall read. Max 49psi, Max load 635kg.
    I inflated them to 45psi and they looked a bit better. But how am i doing on the 'Max load' front?
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi BW,the V6 with 225/45-18 should run with 2.6 bar pressure front,2.4 bar rear, low profiles allways look a bit flat,The maximum 49psi is for different applications on different vehicles,as is the maximum load,running with 45 psi is too much you will get a hard ride and could damage the suspension on rough roads,the handling will allso be affected
    V6 CDTI
    What is the complete specification of the tyre?
    They should be 225 45 R18
    Personally I would only use at least 91W
    On the V6 CDTI with 18" tyres you want the following tyre pressure :
    Front 38
    Rear 35
    I agree though, the front tyres always look underinflated on this car, and others I have seen with the 3.0 V6 CDTI
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    ok, so pressure a bit too high but the weight loading is ok you reckon?
    Quote Originally Posted by BigWilko View Post
    Don't know until you provide the tyre specification
    225 45 R18 tyres could be 91V
    Again, this would be acceptable but I personally would NOT use them
    There is also the 225/45ZR18
    Equally, you may need to contact your insurer to find out what minimum they will accept
    My records show this to be 91H but that is on the EU Conformity Certification of 215/55R16 tyres only
    My car came with 215/50R17 95W XL
    Officially only the 3.0 V6 CDTI automatic needs XL rated tyres, for the manual it is just a few kg below the limit and so I have retained XL tyres
    Having performed a test on standard tyres where a catastrophic failure occurs, it was scary compared to the XL (although that too was a challenge), driving on three tyres in 0.8mm of standing water at 65mph
    Therefore, as above, please post the full specification so that full advice can be provided
  1. Will a 235 tyre go onto a 7.5j wheel?
    Last Post: 11th February 2011, 20:59
  2. Alloy Wheel & Tyre
    By aaruck in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 20th December 2008, 19:29
  3. Insurance Limitations?
    By bill1250 in forum Insurance Chat
    Last Post: 24th April 2008, 07:44
