Results 1 to 2 of 2
Thread: Pioneer 7100BT Headunit and Surround
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default Pioneer 7100BT Headunit and Surround
    Pioneer 7100BT Headunit and Vectra single din surround for sale.
    Excellent headunit has Parrott bluetooth, which has excellent clarity, full ipod / iphone control.
    Only selling as I fancy a change to a double din LCD.
    Excellent condition
    Full Spec from Pioneer Website below cost £230 new.
    Both plugged and unplugged performances in your car.
    Plug and play all your music from a variety of sources – or stream audio wirelessly from your Bluetooth phone. The DEH-P7100BT is versatile and fully-Bluetooth enabled.
    Once your Bluetooth phone is anywhere inside the car, you have full control. Make and receive calls and give voice instructions. An external mic (which is included) ensures that your voice is heard clearly at the other end, noise and interference-free.
    The DEH-P7100BT plays your entire music collection, supporting every commercially available audio file format.
    Hook up your iPod or USB music source via a dedicated input or portable audio player via the rear auxiliary input, and control them directly from the CD Tuner.
    You can control the system with its ‘Rotary Commander’, which works very much like a joystick – essential for navigating through your WMA, MP3 and iTunes audio files. A large white OEL ( Organic Electro-Luminescent) shows 2 lines of 16 characters each, so you can clearly see and control the content.
    The DEH-P7100BT also has 3 RCA pre-outs, so you can boost your in-car set-up with additional amplifiers, subwoofers and speakers.
    Check to see if your Bluetooth phone is compatible [pdf]
    Specifications
    Main FeaturesDEH-P7100BTMax. Power OutputMOSFET 50W x 4CD Player FeaturesDEH-P7100BTDisc Title MemoryYesTrack Search/Scan/RepeatYes/Yes/YesLast Position MemoryYesRandom PlayYesAudioDEH-P7100BTAdvanced Sound RetrieverYesAutomatic Sound Leveliser (ASL)YesBalanceYesMain FeaturesDEH-P7100BTTunerAM, FM (24 pre-set stations)Plays• Your CD collection (including CD-R, CD-RW)
    • MP3, WMA, WAV, AAC compressed audio files on CD and USB
    • Your iPod, iPhone via optional CD-IU50 cable
    • Your USB device via a rear USB input
    • Other music devices via a rear auxiliary input
    • Music streams via your Bluetooth mobile phoneBluetoothYesFront PanelFlap-type, removeable front panelDisplay IlluminationWhite OEL (showing 2 lines with 16 characters each)Button IlluminationBlueRotary CommanderYesRemote ControlOptional CD-SR120 steering remote availableMulti-Language DisplayYesConnectivityDEH-P7100BTAux-inRearDirect Sub DriveYesHard-wired Remote InputYesHigh Voltage Output 4VIP BusYesiPod Direct ControlYesRCA Preout 3 (F + R + SW) Sub-display OutputYesUSB InputYesBluetoothDEH-P7100BTParrot Bluetooth ModuleYesHandsfree TelephonyYesAudio StreamingYesVoice RecognitionYes (for English, German, French, Italian, Spanish and Dutch)Text-to-Speech (TTS)Yes (for English, German, French, Italian, Spanish and Dutch)Additional Bluetooth Features• Phone book transfer
    • 1000 entries for up to 5 individual users (each entry can hold up to 5 unique numbers)
    • SMS alert system
    • External microphone includediPod CompatibilityDEH-P7100BTiPod ReadyYes, via optional cable CD-IU50 Works with iPhoneYesCompatible GenerationsSeptember 2005 onwardsSupported Functions• Battery charging
    • List browsing
    • Music playback (track up/down, fast foward, rewind, pause, repeat and shuffle)Tuner FeaturesDEH-P7100BTRadio Data System (RDS)YesTraffic AnnouncementYesBest Stations Memory (BSM)YesAuto Alternative Frequency SearchYesAuto/Manual Frequency SearchYesPTY SearchYesCD Player FeaturesDEH-P7100BTCD TextYesMP3 Text DisplayYesUSB TextYesAudioDEH-P7100BTD/A Converter1-bitFaderYesGraphic Equaliser7-band with 5 pre-set EQ curves and 1 customHigh Pass FilterYesLow Pass FilterYesSource Level Adjuster (SLA)Yes
    Really is an excellent bit of kit. All cables supplied, can be hooked up to steering wheel controls but I never got round to it. Will supply cables for this also. Do have original box and instructions also.
    Includes fascia adapter too which completes the look.
    £150 ono posted recorded or can be collected.
    Audiville, WM
    bump
  1. Pioneer Headunit and iPod adaptor
    By Keif in forum Parts for sale
    Last Post: 14th April 2011, 21:05
  2. Steering Control on Pioneer Headunit
    By bennyk in forum Electrical & ICE (including SatNav)
    Last Post: 26th October 2007, 15:08
  3. For Sale Pioneer DEH P70BT headunit
    By armoured farmer in forum Parts for sale
    Last Post: 25th August 2006, 09:15
  4. Pioneer headunit upgrade
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2006, 12:38
  5. help pioneer headunit
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2006, 13:40
