Thread: Timing chain kit Z22YH
    Regular Member Sambor's Avatar
    Elgin
    Default Timing chain kit Z22YH
    Hi everyone!Last year I change Timing chain kit in my Vectra Z22YH.I found today that Field Remedy 2366 saying;
    Complaint: Rattling noise from timing chain, often together with elongated timing chain.
    Cause: Blocked timing chain tensioner.
    Production: A modified Z20NET tensioner will be introduced in production with MY 2009.
    Remedy:
    Note: For Z22SE engines please first take note of Quick
    Information 1532.
    In case of customer complaint exchange timing chain
    (including the improved tensioner).
    Improved timing chain kits for engine Z22YH/Z22SE available
    via P&A under partnumber / cataloguenumber:
    --> Kit timing chain for engine Z22YH partnumber: 55569838 /
    cataloguenumber: 6 36 176
    --> Kit timing chain for engine Z22SE partnumber: 55570337 /
    cataloguenumber: 6 36 177
    Does it means that Vauxhall dealer should change my timing tensioner for the one from Z20NET?I just look at my engine and found that they install the same tensioner like was before!For Z22YH!
    anybody knows what should I do in this situation?
    Blantyre
    Interesting and subscribed
    Regular Member ian1401's Avatar
    May 2011
    Exeter
    i had my chain replaced on my Z22YH on the 21/01/2011 they used partnumber: 55569838, numbers stated on invoice
    So it looks like i got a modified one is this correct??
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Quote Originally Posted by ian1401 View Post
    ive got the z20net tensioner on mine as i have the z20net engine but its getting replaced on weds for the second time and after only 32k miles it cant be that good
    Elgin
    Quote Originally Posted by signumboy View Post
    What happened?
    Edinburgh/outskirts
    Mileage : 38000
    Quote Originally Posted by Sambor View Post
    What happened?
    Just rattling its head off
    Regular Member benny's Avatar
    Feb 2006
    dudley
    well hard one to call ...as it is only advise and the chain kit vx sold at that time didnt have the modded tenstioner in it they only started selling them in november last year with the net tenstioner .....also where did you get the feild rem from .. ? ...
    Regular Member eaglepva's Avatar
    Up North
    is this the 2.2 petrol engine or the diesel.
    Elgin
    Quote Originally Posted by benny View Post
    You said November last year,but it says that:A modified Z20NET tensioner will be introduced in production with MY 2009
    I get it from TIS 2000.It si something wrong?
    11 Post(s)
    Quote Originally Posted by eaglepva View Post
    The Z22YH and Z22SE engine codes are petrol.
    The Y22DTR engine code is diesel.
  1. Z22yh Balancer shaft chain help
    By andrewleighton in forum Vectra C / Signum Troubleshooting
    Last Post: 14th May 2012, 16:21
  2. chain tensioner z22yh
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2012, 10:47
  3. Z22YH Cam Chain Rattle @ 41K Miles??
    By Stevie76 in forum Engine & Drivetrain
    Last Post: 16th January 2012, 20:51
  4. Timing chain kit please help!
    By benholden2010 in forum Engine & Drivetrain
    Last Post: 24th August 2011, 20:56
  5. Z22YH In Need Of A Timing Chain...
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 10th October 2007, 10:54
z22yh chain tensioner
when do I change my chain on z22yh
How to change z22yh timing chain
z22yh chain kit
z22yh timing chain kit
z22yh timing chain
z22se improved timing chain
z22se cam chain kit
timing chain opel z22yh
timing chain kit z22yh
https:www.vectra-c.comforumshowthread.php146108-Timing-chain-kit-Z22YH
z22yh check chain tensioner activated
z22yh timing chain change
z22yh chain replacement
z22yh chain replacement interval
z22yh timing chain tensioner
