Thread: help
    Regular Member cr0m81e's Avatar
    dumbarton
    Default help
    the display on my rev counter was showing a picture of a car and spanner it went out when i turned car of and started it again any ideas
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    cars is in limp mode mate allso cc wont be working either afraid its a trip to the dealers to get it on to there tech 2 computer to see if theres any fault codes
    dumbarton
    it seamed fine when i started it up again no fault lights or anything
    Jan 2006
    Dalriada
    Engine management light mate..ecu has logged a fault possibly??
    dumbarton
    what is engine management light on vec c i'm used to older vauxhalls where management light is small pic of engine on mine when i was driving tonight night i noticed a pic of a car and spanner was ilt up but when i turnrd car of the started it again it was off and car seemed fine
    Regular Member cameraman's Avatar
    Leicester
    I've had this on several VX's if it happens again book it in at the stealers otherwise forget about it!!, I had an astra that went into limp at 70mph, 75mph no probs, 70mph for 1/2 mile into limp, ,took 5 visits & 3 weeks in dock to fix it!!. But if its gone away just hope it don't come back.......
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Engine electronics, immobiliser, transmission electronics, diesel fuel filter
    Control indicator for engine electronics (within tachometer display dial)
    If it illuminates when the engine is running, there is a fault in engine or transmission electronics. The electronic system switches to an emergency running programme. Fuel consumption may be increased and the driveability of the vehicle may be impaired. In some cases the fault can be eliminated
    by switching the engine off and back on again. If the control indicator illuminates again when the engine is running, consult a workshop to have the cause of the fault remedied immediately. We recommend your Vauxhall Authorised Repairer.
    If it illuminates briefly, but does not recur, it is of no significance.
    Illumination of A can also be an indication of water in the diesel fuel filter in
    engines1) Z 19 DT and Z 19 DTH. Have the fuel filter checked for water residue. We recommend that you consult your Vauxhall Authorised Repairer.
    If it flashes after the ignition is switched on, there is a fault in the immobiliser
    system.
    dumbarton
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Stay positive: "If it illuminates briefly, but does not recur, it is of no significance."
    dumbarton
    think i'll let the missus use car for next day or 2
