Results 1 to 10 of 13
Thread: Is old fuel OK
    stoke
    Default Is old fuel OK
    My friend found an old can of fuel with about 20L in it.
    Its around 3 years old....
    My plan was to use it in my 1.8 Vectra LS 03 plate.
    Just wanted to know if its a BIG no no.... or if anyone knows what I can do to liven it up.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    I would reserve it for cleaning use only or for the lawn mower
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    79 Post(s)
    Vehicle : Design
    Trim : SRI LEATHER
    Engine : 1.9 cdti
    Year : 56
    Not sure but i think petrol goes off ie after a long period it carnt be used.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    it loses its octane rating goes off... be ok for strimmers n mowers tho.
    Personally I'd chuck it in when the car was 1/2 - 3/4 full.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    If you intend keeping it stored there's an additive you have to put in - well, there was for the old classic cars and 4 star. Otherwise as said, don't use it in your car.
    stoke
    Is there anything I can put in it.... RedEx.... Also im guessding using a higher octane fuel at the pump will help...
    I understand you guys being helpful.... But I really need the fuel tonight... And I got no money till Monday.
    If it's any help, Its been stored in a lock sealed steel jerry can.
    May I ask the question? What's the worst that could happen....
    We talking fuel filter and tank drain.... Or is it gonna mess with the engine block?
    Glasgow
    Worst that could happen is your car will run like a bag of spanners and cut out.
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Deathtopia View Post
    It doesn't matter if it's in a sealed container, it deteriorates with age, and 3 years is way too long. I had a classic car off the road for 6 month and I had to drain the tank and refill with fresh fuel before it would start.
    I'd be very surprised if your car will run on it, even if you had say, 40 litres in the tank, it would be like having water in it, adding this.
    The correct additive for keeping it ok should be added at start, no good now, chemical composition willl have changed.
    stoke
    Ahh ******... well at least I've got 20Liters of cleaning fluid out of this.
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. Fuel housing sensor/fuel temp senser a
    By sri adi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 10:15
  3. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
