Results 1 to 10 of 25
Thread: Do Sri XPII / xp2 have a brake pad warning light
    Barnsley
    Default Do Sri XPII / xp2 have a brake pad warning light
    My brakes are grinding and can't see if the pads are warn down ,
    Do these cars have a warning light or anything cone on the cd70 like when we have a bulb out ?
    scottish region
    It should mate
    Barrow In Furness, Cumbria
    Yes, they should have the warning light providing the wiring is connected up to the pads.
    Barnsley
    Got a loud grind when brake but no warning unsure what to do
    I would check the condition of the brake pads asap. It is possible to remove the pad wear sensor and fool the system into thinking that it is still in place. It sounds like one or more of the pads has worn down to the metal.
    Barnsley
    Will have to check it's 08 had all new when I bought it from perrys in jan with 40k now on 62k
    Regular Member Geo77's Avatar
    Sep 2009
    North Yorkshire
    I had to put new pads AND DISCS on @ 30k!!
    Pads had worn right down and scored the discs!!
    Our beloved Veccy's tend to wear rear heavy, which is odd!
    Quote Originally Posted by kirky2k4 View Post
    If the noise is coming from the rear wheels and it is down to worn pads you wouldnt get a warning on the dash anyway as there is only one pad wear sensor and it is fitted to the front nearside caliper.
    defo do mate..
    Regular Member KELLSY84's Avatar
    Feb 2011
    belfast
    I have an sri xp2 and it DOESNT have brake pad sensors.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. 3rd brake light warning
    Last Post: 12th January 2013, 13:15
  3. Brake Pad warning light
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2010, 23:38
  4. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  5. Brake Pad Warning Light
    By BigTunz in forum Suspension, Wheels & Brakes
    Last Post: 16th July 2006, 22:45
