Results 1 to 10 of 17
Thread: Saab green injector upgrade
    Worksop
    Default Saab green injector upgrade
    Wots needed just the injectors? Or do I need wiring loom etc
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Quote Originally Posted by tomo41 View Post
    think you need another Map also as these are the ones they use for stage 3 BSR Map but im sure are in engines after 2006 ,,, someone will correct me if im wrong
    WGAF#5
    Indeed a map is needed too
    Worksop
    wots happens if i fit these and raise boost myself till i get a map sorted
    Edinburgh/outskirts
    Mileage : 38000
    Not sure my friend ...would just need to suck it an see
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I think it may overstep or underfuel not sure but I mo the map is Defoe needed to time when the fuel is put in and how much
    Edinburgh/outskirts
    Mileage : 38000
    Im sure Duncan had an issue with over fuelling in his motor after fitting those injectors and he had the BSR stage 3 Map
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    you can drive it but it will not be fueling correctly until you have a remap to deal with them correctly. No loom change is required as its the same delphi connections. They are easy enough to fit yourself but you should wait until you get a remap sorted.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I drove mine on the green injectors after fitting them, but only to get to Neo Brothers for the re-map. Was advised by them to be very steady driving it down to them to prevent over-fueling until the re-map was done.
    Only did it this way because I didn't want to pay them to fit injectors I was perfectly capable of fitting myself
    Jun 2011
    Lancaster
    Vehicle : VXD
    Mileage : 90000
    Any1 got a pic of what these look like cheers
  1. Green injector upgrade z20net
    By tomo41 in forum Petrol Engine related
    Last Post: 12th January 2012, 18:40
  2. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  3. Saab and Vauxhall fuel injector question...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 19:37
  4. green, green eyes...
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2006, 18:01
saab green injectors vectra
