Thread: Oil. 5W-30 or 5W-40?
    Regular Member Ross DTi 2.2's Avatar
    Mnster, NRW, Germany
    Default Oil. 5W-30 or 5W-40?
    Guys,
    I'm changing my oil and filter tomorrow with the help of some previous useful advice from other forum members.
    I've bought some 5W-40 fully synthetic Valvoline SynPower oil. Its not overly expensive and in my experience it does a very good job. I've been thinking of taking it back and swapping it for the same oil but the 5W-30 version as Valvoline reckon its better for fuel economy.
    Any thoughts?
    Regular Member blr123's Avatar
    Dundee, scotland
    In the winter months Ross the 30 is better as it's thiner so it circulates better/faster so gives better protection especially on start up......just an opinion thought
    Bryan
    The 5-30 is classed as a longlife oil with VX - helps the longer service intervals. But its up to you, 5-30 should give a better MPG. All depends if you leave your oil in for the 20000 miles VX say you can. If you do more frequent changes I'd go for the 5/30.
    Quote Originally Posted by blr123
    Bryan
    I think its only thinner at operating temperature Bryan. The cold pouring rate and freezing temp is identical (5W) so cold start circulation shouldn't be any different between the two. It gets bl**dy cold here BTW
    I think the 5W-40 will give better lubrication when really pushing it, but I don't really push the car that hard so I'm thinking of the MPG benefits of the 5W-30 now.
    Decision made, changing to 5W-30 it is. Thanks for the opinions guys.
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    you should have 5w30 longlife oil,normal 5w30 fully synthetic oil is not the same oil and will need changing more often
    member of the smoke patrol 230bhp+
    Quote Originally Posted by solorider
    vauxhall will charge you about 25 for the long life oil and about 7 for the fillter
    or even better i got kwik fit to do mine r 24.99 ,,,,,suckers,,,,,,
    they had to use a vauxhall fillter in mine then had to put mobil 1 the the car
    only tell them about the oil the car has after they drop yours out
    they look at the 2.0 dti info and think its ok ,,,,,,,wrong,,,,,,,,
    go to vauxhall and give them your number plate details and there will print out you car engine detail for you
can a 5w40 go into my 5w30 vauxhall vectra
can I use fully synthetic 5w 3o on my vectra 2005
vectra c 5w30 vs 5w40
vectra c 5w
5w40 engine oil vauxhall signum
whats the difference between 540 and 530 oil vectra c
5w40 vectra c
is 5w 40 oil good for a vauxhall vectra
why 5w30 instead 5w40 in vectra
can i put 5 40 oil in a vectra c
can i put 5w40 oil in a vauxhall course
الفرق بين زيت 5w30 و 5w40
540 ol ok for 2.2 vectra
5w-40 for vectra diesel
vectra c 2.0dti oil 5w-40
5w40 do vectra c
is w 5-w 40 fully synthetic oil OK for a vectra
opel vectra 5w40
opel vectra c 2.2 dti 5w40
I have put 5w 40 oil in my vauxhall vectra is this a problem vauxhall vectra
corsa c 5w 40
corsa c 5w 30
5w40 for vectra
5w40 opel vectra
5w 30g oil vectra 2.2
