Thread: CDTI - carb cleaning exercise 020911
    Regular Member Jim Bob's Avatar
    Widnes, Cheshire
    Default CDTI - carb cleaning exercise 020911
    Hi
    I'm going to attempt to clean my EGR out tomorrow without taking it off. I've read on the forum that this can be done (maybe not as effective, but im not having any symptoms at the moment) by spraying carb cleaner into the air intake.
    I understand its not advisable to spray it so it goes through the MAF sensor - has anybody got any pictures to show me exactly where I need to spray it?
    Thanks for any help/advice
    J
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Just take it off buddy, It's not that hard! I was a worried about trying it myself to but its really easy. An hour or 2 and it will be cleaned and fitted again
    Widnes, Cheshire
    It scares me though! and I've got no Torx drivers
    Barrow In Furness, Cumbria
    Spray it in after the connector that sits in the intake pipe. Its got a wiring block going to it.
    Sodding Typical on Sea
    It won't really do much to clean the EGR using the spray as it is a negative pressure zone so doesn't draw the air into the chamber. The only truly effective method is the very simple removal, 4 x 10mm bolt / nut's and 2 x 13mm bolts
    CHESHIRE
    Jim bob I'm from widnes area could pop round show you what to do mate its dead easy .
    Jun 2011
    belgium
    Quote Originally Posted by Jim Bob View Post
    Don't worry about it! Just make sure you don't drop the torxbits down the engine spent more time trying to get it out than cleaning and refitting egr
  1. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  2. New Exercise Program
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 13th February 2009, 11:16
  3. exercise
    By tonypc1 in forum The 'Off Topic' room
    Last Post: 2nd May 2008, 15:12
  4. New Exercise Programme
    By steve.s in forum Comedy & Humour
    Last Post: 8th July 2007, 18:56
