Results 1 to 10 of 18
Thread: drive shafts?
    Edinburgh
    Default drive shafts?
    All,
    A few months ago I noticed if I accelerated reasonably when I was going round a corner, i could hear a kinda rumble noise coming from the car. More recently, when I come through the clutch there is a kinda popping noise coming from the car as well. I'm wondering if the CV joints or the drive shafts might have an issue? Any thoughts on what it could be?
    It doesn't seem suspension related as the noise doesn't happen when going over bumps only when power is applied. When driving smoothly there is no noise. It is most noticable moving away from stop into 1st perhaps because there is least road noise.
    I've checked the boots and none of them are split (inner or outer)
    Thanks,
    Ian
    Edinburgh
    Bump
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Knackered CV joints sound a bit more like when you crack your knuckles than a rumble. if you know what I mean? Turn the steering full lock and drive off slowly, you'll soon hear them.
    Edinburgh
    So the kinda popping noise happens even when the wheels are straight. At first I thought it was like a creaky spring but it doesn't make a sound going over speed bumps etc just when I come through the clutch and the power goes to the wheels.
    Edinburgh
    Edinburgh
    ok so a friend of mine suggested engine mount and said I should try and "rock" the car with the hand brake on to see if it still made the noise and the engine moved. I can't hear it. I've also tried slowing the car down sharply in neutral and I can't hear it so it only appears to be present when power is being applied to the wheels or taken away. most noticable in 1st & 2nd.
    Edinburgh
    Edinburgh
    Found the problem, was loose engine mount. Folks that did my DMF obviously didn't do then properly. I missing, 2 bolts working their way loose. Tighten 2 that are still there, noise gone
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Just seen this thread. Nice find on this one. Had found a loose engine mount on the front of mine, no reason as to why except it was in a light front ender but didnt give no knocking noises.. Had it happen once before on an old escort van i owned, could tell it was the engine mount as when i went to pull off the bonnet raised up!
    Edinburgh
    Above is what I found. not particularly happy but at least it was an easy fix and didn't cost anything.
  1. 2.0/2.2dti drive shafts
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 14th October 2012, 15:20
  2. Where to buy drive shafts
    By logi6260 in forum Engine & Drivetrain
    Last Post: 14th March 2012, 09:15
  3. drive shafts
    By tappetpaul in forum Engine & Drivetrain
    Last Post: 14th April 2011, 01:16
  4. Any advice for How 2 replace drive shafts ?
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2010, 18:19
  5. Drive shafts
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2007, 18:05
