Thread: Do I have rear brake sensors?
    Regular Member brotherkennyh's Avatar
    Swadlincote
    Default Do I have rear brake sensors?
    I have a 04 reg 2.0DTI hatchback.
    I want to know if my car has rear brake sensors before I crawl around to find out.
    I keep reading that the vectras do not have rear brake sensors, but the Euro car parts website apparently sells rear sensors for my car, while no one on ebay seems to be selling any.
    The brake pad wear sensor light has come up. I know the front pads are not due because I changed them 6 months ago and haven't done enough mileage to wear them out.
    I am thinking that either the rear pads do have a sensor and are due or that there is no rear sensor and there is a problem with the front sensor.
    Can anyone shed any light on this?
    Kenny
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    No, the only brake pad wear sensor is on the front passenger side.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    i would assume if your brake wear light is on it will be a dodgy sensor wire in the ns/f wheel whip the wheel off and check it out
    11 Post(s)
    Quote Originally Posted by brotherkennyh View Post
    Or are they ABS sensors?
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The ABS sensors are part of the hub assembly and can't be purchased seperately IIRC the only sensor I know for the rear axle is the level sensor for the AFL/Xenons
    Regular Member Jezzy's Avatar
    S.E
    Forget about any rumours of rear sensors; it's highly likely that the one and only pad wear sensor on the car (front N/S as Ian said) is damaged.
    Swadlincote
    See link below for the part I was querying. This come up in a serch for parts for my car.
    http://www.eurocarparts.com/ecp/c/Va...959377e&000369
    I can't see anything wrong with the front sensor.
  1. brake sensors
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 02:17
  2. Brake Sensors
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2011, 08:38
  3. Brake wear sensors.
    By fastcarmanaic in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 23:36
  4. Brake sensors ? ? ?
    By Batesie in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2008, 03:02
  5. Does the 1.9 sri 55 have brake sensors
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 16th June 2008, 22:28
https:www.vectra-c.comforumshowthread.php146068-Do-I-have-rear-brake-sensors
vectra c rear brake sensors
