Thread: Upgrade / Big Brake Conversion
    Default Upgrade / Big Brake Conversion
    Hello All,
    Just checked my brakes and have noticed they are quite worn. Time to upgrade me thinks!
    Can anyone recommend me a decent brake upgrade? I was looking at AP racing but they only list the Vec B upgrades.
    I've got 17" pre facelift SRi wheels.
    You could fit the vxr 345mm brakes.
    Regular Member R2XPT's Avatar
    Scotland
    There are lovely 4 pots with 330 mm discs from neo bros or vxr brakes like mines, stop amazing
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    If you do a search there is loads of reading on the Vec C brake upgrade options. Assuming you have 285mm fronts there are 302mm (earler GSi), 314mm (later GSi and 2.8 V6) and 345mm (VXR) iirc. I have 314mm fronts with 292mm rear (V6 and VXR) and find them more than adaquet.
    These are brakes when I painted them.......
    http://www.vectra-c.com/forum/showthread.php?t=104312
    The 314mm front caliper is pretty big and exactly the same size as the 345mm VXR front caliper but unfotunately pad fitment is slightly different.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    I have upgraded mine from 285mm to 314mm. The difference is amazing. Did the same on my old 2.0T (upgrading from 302 mm to 314mm and that made a big difference...but upgrading from 285mm to 314mm is something else).
    However 314mm brakes may not fit if you have 16" wheels. If you have 17" or bigger, then just do it. Braking quickly at motorway speeds with 285's is no laughing matter.
    Jan 2006
    Hornchurch
    I run 345mm setup with police spec pads from the 314mm setup
    also you can fit 314mm setup under 16's
    345mm need 17's
    how much do you want to spend on a brake kit ?
    ap's your looking at around £1500
    314mm about £300 if your near essex I have my old v6 314mm setup
    I could dig out for you
    345mm about £600 under a 17
    its all about what you want to spend I have had 314 on my vectra 1,9
    changed to 345mm
    sold the vectra so i fitted the kit to my zafira
    £ for £ the 314 kit was the best upgrade of the lot
    Scotland
    Quote Originally Posted by dannysport18 View Post
    345mm need 17's
    changed to 345mm
    Gorgeous wheel colour what's colour of paint is that?
    Jan 2006
    Hornchurch
    Quote Originally Posted by R2XPT View Post
    its a powder coating I will find out the name of it for you
    its on the car looks nice
    Scotland
    Stunning painting my wheels soon and love anthracite
    Jan 2006
    Hornchurch
    I changed from a set of 4 pots back to the vec setup my on zafira
    the vectra setup as good around town and motor way speed
    but on a track the 4 pots are a bit better but for road use your not going to notice
  1. 314 to 345 brake conversion?
    By larann in forum Handling & Braking
    Last Post: 19th July 2011, 19:13
  2. Big brake conversion
    By Meriva OPC in forum Handling & Braking
    Last Post: 19th February 2006, 12:47
  3. Big Brake Conversion
    By AJA in forum Quick Photo Album
    Last Post: 7th October 2005, 00:42
vectra c big brakes
upgraded car brake kit liverpool
vauxhall signum big brake conversion
vauxhall zafira a gsi opc suspension
vectra brake upgrade 314
vauxhall signum bigger brake upgrade
vectra c big brake upgrade
biggest brakes that can go on a vectra c
meriva big brake upgrade
zafira a big brake
