Likes Likes:  1
Thread: UHP4 BT TECH2 programming
    milan
    Default UHP4 BT TECH2 programming
    Hi All,
    my car is a vectra c station wagon, I've bought a UHP4 2010 board and now I need to install it and configure it.
    Could you please guide me step by step on such task.
    Please help me.
    Bye
    Msqualo
    WGAF#5
    its been covered lots of times on here before (remember the search button is your friend ).. but a PM to AndyL may assist
    and here's one of the threads to read
    http://www.vectra-c.com/forum/showth...highlight=UHP4
    milan
    Thanks deztroyer,
    I found a guide related to astra series, I was wondering if someone could have a look and confirm that the same programming could work on the vectra c as well.
    I know it is a bit long to read through, nevertheless it would be great if someone that did it before could help me out.
    Msqualo
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    As mentioned drop a polite PM to Andyl or Tramman and im sure they will help you out.
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    Accidental thread ressurection...
    That's what you get when you search and find an old thread.
    Programming is the same for most Vauxhalls.
    The main difference is the code index value.
    Each model has it's own code.
    From memory estate is 022 and hatchback is 023.
    Regarding programming device.
    Most people with the early OpCom will find that a 2010 device cannot be programmed with 100219a software.
    You really need at least the latest 2013 or 2015 software.
    As you do not have "phone SAFE" as a pop up message, then at least the UHP4 isn't still programmed to the donor car.
    Only Tech 2 will be able to deactive anti theft protection to indevidual components. Assuming you had the donor vehicle's security code of course.
  6. Likes Dog_Book liked this post
  1. I nearly have everything for my UHP4 now
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2012, 09:32
  2. help with tech2 programming auto AFL
    By emsedk in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2012, 16:54
  3. Fitting replacement engine tech2 ecu programming??
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 1st July 2011, 18:51
  4. Tech2 Programming.
    By Adam B in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2010, 20:55
  5. Need help 4 TECH2 Programming
    Last Post: 24th May 2010, 20:51
tech2 vauxhall signum pdf
vauxhall uhp4 program
vauxhall uhp4 index
Vauxhall programmer north east
programming uhp4
