Thread: help needed
    Jul 2011
    UK
    Year : 06
    Default help needed
    Is this any good wanting a polisher
    http://item.mobileweb.ebay.co.uk/vie...id=05849531939
    Also will this remove swirls as by hand its impossible then can a use this to seal it with extra gloss autoglym
    Woodbridge
    This is a rotary, If you are a beginner then you could start with this, but it is suggested you practice with it on a scrap panel first as it is possible you could burn through your paint if you do not know what your doing.
    Have a read of this
    http://www.vectra-c.com/forum/showthread.php?t=144604
    And
    http://www.vectra-c.com/forum/showthread.php?t=144666
    Jul 2011
    UK
    Year : 06
    Hmmm don't think a will don't want to damage paint
    scottish region
    pmsl
    Jul 2011
    UK
    Year : 06
    Never used one or a grinder but surly can't be hard if slow speed and don't stay one place
    Woodbridge
    You can pick up some pretty cheap DAS 6 now. That is very beginner proof and works very well, I think taff's post with the 10Hr correction was with a DAS6.
    Woodbridge
    Jul 2011
    UK
    Year : 06
    Cheers fella they easy to use and won't kill the paint a looked on eBay and all am getting is magiurs and there over 200 pound :0
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by marc vectra sri View Post
    they are easy to use ,have a look on detailing world .com and you may find one in the for sale threads . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Woodbridge
    I think the second option is the best to get up and go with it. Easy to use, but do some reading of the threads I posted before on how to use it, It is not just a case of add polish and go, the benefit of using a DA is that unless you hold the pad in the same place for a long period of time you wont go through the paint. The new megs G220 V2 is a very good piece of kit however as you say it is quite expensive, but you can acheive the results you want with a DAS6.
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
