Originally Posted by
mattster87
Filled Up this morning and as I accelerated out of the station, there was a loud thud noise and the car slowed (I did not brake), I then couldn't get the car into 2nd or 3rd gear - First and Fourth were fine, did not try 5th. However even when in first I had no drive.
Got the car home now, and the current situation is;
Get in car,handbrake is on, start ignition, clutch down, select first (all gears now engage fine), clutch up, Car will rumble like it is about to stall. I now have my foot completely off the clutch, release handbrake, car will very slowly crawl forward, but adding revs does not make a difference in speed. Reverse is the same.
There is no oil leaking or metal shards underneath the car, is it possible both the gearbox and clutch have failed? Car had a new clutch 15k Miles ago.
Matt
