Thread: Wiring in drivers side boot compartment?
    Jun 2011
    Kent
    Default Wiring in drivers side boot compartment?
    What is the wiring in the drivers side boot compartment for?
    It's a small loom with a plug on the end, it looks like it is an original part of the cars loom and not an add on.
    Any ideas, CD multi changer perhaps?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Could well be the wiring for the tyre pressure monitoring option
    May 2011
    bispham, blackpool
    im sure i have that wiring as well but im sure mine is connected to something i thought it was to do with towbar will check in the morning when its light i will empty it out as mine is full of tools pump etc
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    not for cd autochanger as that is in the dash.
    Jul 2009
    Brighton
    More than likely it's the TPMS as mentioned above.
    On the passenger side, it would be the reversing sensors (taped up and plugs into the reversing sensor unit).
    In the spare wheel well, there would be the towing electrics, plus (maybe) the other part of the parking sensors loom (the bit that connects to the sensors).
    HTH
  1. Electric Cable in Boot Compartment
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 5th November 2012, 21:39
  2. drivers side, side reapeater
    By ks246 in forum Parts for sale
    Last Post: 26th May 2009, 17:31
  3. Side/rear load compartment net for Vectra C
    By Duncan in forum Parts for sale
    Last Post: 29th November 2007, 13:09
  4. Wiring amp to boot
    By thegoldenbullet in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 22:10
  5. drivers side cenral locking switch and boot opener not working
    By mattdiesel in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2006, 22:40
