Results 1 to 10 of 11
Thread: Pioneer unit help
    Regular Member johnmac's Avatar
    Apr 2006
    Inverclyde
    Default Pioneer unit help
    Just bought a DEH-P6800MP unit from Ebay.3 months old.Seller specified "collection preferred" but will post but not accept returns.Got the unit today and tried to fit using the Vauxhall facia and adaptor kit.As most people will be aware that have changed their head unit,there is a 3 bit plug that connects to the existing Vauxhall connection,this then runs to 3 x seperate connectos.On the Pioneer connections it runs into 2 so when using the Vauxhall connector there is 1 x connector "free".Plugged the other 2 in but when I turn on the ignition,there is nothing from the unit.The fuse is ok and there is 12v.Have I done something wrong OR is the unit "duff"
    John.
    SOUTH SHIELDS
    Mine did the same (jvc) had to swap two of the wires think it was ignition live and ground
    Sometimes need to swap the red and yellow power cables round on Pioneer units. That might be whats up?
    Here, there and every where!
    Try swapping the yellow and red around m8.
    Apr 2006
    Inverclyde
    Cheers Guys. That's what it was.Saved a really cheeky mail being sent to someone. One other question......Now that these wires are swapped,is there anything else to watch out for? Should the blue remain connected (remote)
    Having the blue connected powers the signal amplifier for the FM aerial... if you disconnect it you will get less reception on FM radio, the only plus with disconnecting it is it stops the date disappearing off the MFD when the radio is on.
    Apr 2006
    Inverclyde
    Should I be able to turn the unit on,when wired up,without the key in the ignition.Had a quick go at checking the unit today (not fitted it permanently yet,didn't have time) and it seems that it won't function without the ignition (I'm assuming due to the red/yellow swap).Is this normal?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    my pioneer is the same john i need the ignition on
    Regular Member Damian's Avatar
    Market Drayton
    Jamie,
    When you say the blue wire do you mean the one that forms part of the aeriel plug. If I put my tester on it should this have a voltage across it to power the signal booster.
    Currently my reception is beyond poor and I am thinking that this may be the problem. Should it have 12v on it, if so I could connect it up to an ignition controlled circuit it it is currently not connected anywhere ??
    Regular Member Harry's Avatar
    Uxbridge, London
    i've got my jvc unit to power up without the ignition being on.
    you need to connect both the yellow and the red wire from the headunit side to the yellow wire on the car wiring side. there should be bullet connectors to make this really easy.
    i take it all you have done is swap the yellow and red.
    check the installation manual but i'm pretty sure this is what you need to do to get it permanently powered
    let us know how you get on
  1. Insalling Pioneer*DEH-4200SD unit
    By Dane in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2011, 01:41
  2. pioneer hd-unit
    By kenny1zero in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2008, 20:59
  3. pioneer head unit
    By billyyoung in forum Parts for sale
    Last Post: 12th February 2008, 22:24
  4. Pioneer Head Unit
    By bluebirds1975 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2007, 19:55
  5. pioneer dvd head unit
    By david-bell in forum Electrical & ICE (including SatNav)
    Last Post: 14th November 2005, 23:15
