Thread: CV Joints / Driveshaft
    Regular Member VXR_DV's Avatar
    South Coast
    Default CV Joints / Driveshaft
    I'm getting a clonking sound at low speed (20-30mph) when I drive on poorly surfaced roads.
    It sounds like suspension, but bushes, dampers and springs seem okay to my untrained eye.
    However, if I grab the LHS drive shaft, I can move it a couple of mm inboard/outboard, and it makes the same "clonk" sound I am hearing from inside the car at each end of the travel. Trying to move the driveshaft on the wife's Golf (110k miles) and I can't move the shaft at all.
    Is this normal?
    Has anyone else experienced this?
    Will it be just the outer CV or the driveshaft as well?
    Any idea of likely repair costs?
    Thanks!
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Worn CV joints tend to clunk more when turning a corner - does this make your noise worse ?
    May 2011
    tidworth
    no i have this nose to,i think they said it was the drivers side roll bush or something the garage said it would cost me £54:00+vat
    South Coast
    Quote Originally Posted by JagRigger View Post
    Not really. It just clonks away on uneven roads, on the straight, same around the corners.
    Handling seems normal otherwise, and at higher speeds, the noise can't be heard.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Even although the bushes look fine they still may need replaced. Have you looked at the drop links?
    scotland
    driveshaft is normal , jack it up and pull at the bottom of the wheel ,push it out then in whilst looking at the bottom balljoint , will prob be the lower ball joint so need to replace the wishbone , easy enough job .
    HTH
  1. Inner CV Joints
    By Gmc12 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2013, 17:22
  2. Replace cv joints or whole driveshaft?
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 14:26
  3. bad joints on pcb
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 08:31
  4. Inner Tie Rod Joints
    By Electricdave in forum Suspension, Wheels & Brakes
    Last Post: 8th June 2010, 19:29
  5. Ball Joints
    By xaviroller in forum Suspension, Wheels & Brakes
    Last Post: 26th June 2009, 20:10
