Results 1 to 10 of 18
Thread: Z20NET Timing Chain Parts
    Regular Member Jezzy's Avatar
    S.E
    Default Z20NET Timing Chain Parts
    A couple of people have asked recently for the part numbers for the items needed to replace the timing chain on the 2.0T; I found this list on the 'net, although I haven't checked the numbers yet so can't speak for the accuracy of it:
    • 11518061 screw
    • 12608580 chain tensioner
    • 12788929 chain gear
    • 13104978 chain control
    • 24424758 chain gear
    • 244435052 gasket-timing gear casing
    • 24449448 chain control
    • 24461834 chain
    • 55352124 timing chain
    • 55557168 chain gear
    • 90537299 chain control
    • 90537300 chain tensioner
    • 90537336 chain control
    • 90537337 chain control
    • 90537369 chain control
    • 90537370 chain
    • 90571925 crankshaft seal
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    That parts list must include the balancer chain parts aswell. You dont get half of them in the timing chain kit, especially gaskets
    S.E
    What was the part number for your kit?
    Regular Member Keif's Avatar
    In the Garage
    The Part Number for the Z20NET timing chain kit is 55352124
    In the Garage
    Full Part Numbers are
    Z20NET Timing Chain Kit - 55352124
    Consisting of.
    • 12608580 - TENSIONER, ASSY., TIMING CHAIN -QTY 1
    • 13104978 - RAIL, GUIDE, TIMING CHAIN - QTY 1
    • 12577163 - JET, ASSY. - QTY 1
    • 11516425 - SCREW, HEX.HD., M6 X 30, TENSIONER, TIMING CHAIN - QTY 1
    • 11516425 - SCREW, HEX.HD., M6 X 30, JET, ASSY., TIMING CHAIN - QTY 1
    • 12788929 - SPROCKET, CAMSHAFT - QTY 2
    • 90537337 - RAIL, GUIDE, TIMING CHAIN - QTY 1
    • 24424758 - GEAR, TIMING, CRANKSHAFT - QTY 1
    • 90537451 - SCREW, TIMING SPROCKET ON CAMSHAFT - QTY 2
    • 11588522 - BOLT, SHOULDERED, TIMING CHAIN GUIDE RAIL TO CYLINDER BLOCK - QTY 2
    • 24461834 - CHAIN, TIMING - QTY 1
    • 24449448 - ARM, TENSIONER, TIMING CHAIN - QTY 1
    • 11518828 - SCREW, TORX, TIMING CHAIN GUIDE RAIL TO CYLINDER BLOCK, UPPER - QTY 2
    • 11519784 - SCREW PLUG, FRONT TIMING CASE - QTY 1
    Balancing Chain Parts
    • 55557168 - GEAR, CRANKSHAFT, BALANCE SHAFT CHAIN - QTY 1
    • 90537369 - RAIL, GUIDE, BALANCE SHAFT CHAIN, LOWER, LH - QTY 1
    • 90537336 - RAIL, GUIDE, BALANCE SHAFT CHAIN, UPPER - QTY 1
    • 90537299 - ARM, TENSIONER, BALANCE SHAFT, ENGINE, RH - QTY 1
    • 11516425 - SCREW, HEX.HD., M6 X 30, BALANCE UNIT CHAIN TENSIONER TO CYLINDER BLOCK - QTY 3
    • 11518064 - SCREW, HEX.HD., M6 X 30, BALANCE UNIT CHAIN TENSIONER TO CYLINDER BLOCK, RH - QTY 1
    • 11588522 - BOLT, SHOULDERED, BALANCE UNIT CHAIN TENSIONER TO CYLINDER BLOCK - QTY 2
    • 90537300 - TENSIONER ASSY., TIMING CHAIN, ENGINE VIBRATION DAMPER BALANCE UNIT - QTY 1
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    Does anyone have the prices of the above at all. I'm looking for things to do to my car lol.
    I know the timing chain is the main one what is the balancing chain pls?
    Is this the same as the tensioner thingy that some people find rattles.
    I just want to get all the belts and things altered on mine for new ones any help with part numbers etc would be great
    Jul 2010
    west mids
    Ok I am totally confused found one thread stating
    Modified alternator pulley 93172295, belt 55351458, tensioner 24430296
    Another saying
    Belt 55351458, tensioner 24430296 and crankshaft pulley 55355289
    I am after the parts to change to change the rattle that you can get on the z20net. I don't have it yet but would like them replaced anyway.
    Jul 2010
    west mids
    Another saying
    South east
    Quote Originally Posted by accveccysriturbo View Post
    Another saying
    The belt (55351458) isn't anything to do with the timing chain, it's for the alternator and a/c compressor, it's the one you can see on the outside of the engine, it has a tensioner that starts to make a noise.
    The timing chain is hidden away under a sealed metal cover (to keep the lubricating oil in place) and it has a tensioner as well. The balance chain is behind the timing chain.
    Jul 2010
    west mids
    I believe its the belts etc on the outside which can cause a slight rattle on start up. These are the numbers I am after
  1. Z20NET Chain.
    By bigjohn1969 in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 04:01
  2. Z20NET timing chain
    By vectra100turbo in forum Engine & Drivetrain
    Last Post: 21st April 2012, 08:58
  3. Z20NET timing chain
    By vectra100turbo in forum Vectra C / Signum Troubleshooting
    Last Post: 18th March 2012, 23:12
  4. Z20Net Timing chain
    By signumboy in forum Engine & Drivetrain
    Last Post: 9th September 2011, 09:43
  5. 20T Z20net Timing Chain Help
    By alanwh in forum Engine & Drivetrain
    Last Post: 21st March 2011, 10:59
z20net chain guide
vectra c z20net timing tools
z20net timing chain kits
