Results 1 to 10 of 16
Thread: Z22SE using lots of oil
    Regular Member Nato's Avatar
    Risca, South Wales
    Default Z22SE using lots of oil
    Anyone have any idea why my 2.2 SRi has started to use a lot of oil? I checked the oil this morning and it was almost on empty! I topped the oil up about 8 weeks ago, and now it appears that I am going to need to do so again. There are no obvious leaks from the engine, and there does not appear to be any loss in performance or fuel economy. I have a slight rattle on start up, which I presume is just the normal tappety cold characteristic of the engine, but no other real indication of a problem. Can anyone shed some light?
    Full Member gibbon7000's Avatar
    lincs
    What oil are you using. any smoking from the pipes??
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Risca, South Wales
    10W40 on the last oil change. No excessive smoke from the pipes, just the usual little bit when cold. Did the rocker cover gasket not so long back, and on the last service there was a slightly oily spark plug.
    Glasgow
    Should be 5w30 fully synthetic oil. That rattle noise when the engine is cold could be the timing chain needing replaced.
    Risca, South Wales
    Quote Originally Posted by byebyeitsagsi View Post
    I don't think the rattle is the chain, as there's no rattling under load, and not when the engine is warm either. The oil choice is easily fixed
    11 Post(s)
    Quote Originally Posted by Nato View Post
    The chain is more likely to rattle when cold and not under load. It will also quieten down when warm as well.
    If it still has the original tensioner, then this is not only spring loaded, but also pressurised by oil as well. My tensioner was sticking, and the field remedy to solve the problem was to fit a revised tensioner that they use in the 2.0 turbo engine.
    Glasgow
    As big dave said, the tell tail sign it needs replaced or is likely to fail is if it is noisy when cold.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Stick with the 10w40! Is the same plug oily again?
    Risca, South Wales
    This goes everything I've been told about the chain on the 2.2 then guys. Not that I don't appreciate the input, but it is a different viewpoint to what I've been told and read in the past. I'm also pretty sure the rattle is not coming from the chain.
    I'll be checking in the morning, as I've got a couple of jobs to do. What are you thinking?
    11 Post(s)
    Try the screwdriver stethoscope ## to see if you have a noisy tappet (sticky hydraulic valve lifter).
    ## Place the blade of the screwdriver on the rocker cover and the handle to your ear. This will amplify any sound from the rocker to your ear and might be able to pinpoint where the noise is coming from.
  1. Replies: 5
    Last Post: 21st September 2012, 17:41
  2. z22se mpg
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 19:03
  3. z22se in a vec c
    By benny in forum Engine & Drivetrain
    Last Post: 30th August 2007, 00:05
  4. Replies: 12
    Last Post: 9th April 2007, 01:20
z22se oil spark plug
is vauxhall 5w30 oil ok in a Z22SE engine
z22se 10w40
