Thread: Y can't I get my lambda sensor out
    Aug 2011
    salisbury
    StatsVehicle Info
    Angry Y can't I get my lambda sensor out
    An hour and a half trying to get it out and still it won't move looks like I'm gunna have to pay to get it done after all
    Jul 2011
    hamilton
    StatsVehicle Info
    usualy if the sensor is that tight mate if you try to heat it it will reck the threads when taking it out so be prepared to buy a new down pipe mate .....
    Aug 2011
    salisbury
    StatsVehicle Info
    Quote Originally Posted by skinnybigc View Post
    I'm hoping a garage will have better luck I only had the car a few weeks and looks like it's gunna get expensive lambda sensor, possible swirl valves looking at the gunk by em maybe a down pipe aswell now, and looking throu the forums I need my injector wiring changed, sounds like I also got a dump valve ATM from what I read intercooler pipes may have a leak
    May 2011
    bispham, blackpool
    StatsVehicle Info
    turn engine on and leave it ticking over for a good half hour let it get really hot it will be really easy to get off thats all a garage will do but they will charge you for it
    Aug 2011
    salisbury
    StatsVehicle Info
    Quote Originally Posted by 6009tristanb View Post
    I am tempted to give it another go I really wanted to do most the work myself but not being the greatest with cars kinda don't help matters, would it make it easier if I took what looks like a heat ahold off by the down pipe ?
    scotland
    StatsVehicle Info
    it will need heat mate and a proper lambda socket this will make it come off a doddle .
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    StatsVehicle Info
    Quote Originally Posted by gsxrster View Post
    as above oh and dont forget 3 shredded wheat for breakfast
    Jun 2011
    Elland
    StatsVehicle Info
    Quote Originally Posted by danno91 View Post
    The injector wiring is not expensive and available as a VX replacement part - details somewhere on this forum, but I think it's around 12 - 15£.
    Identify where the air leak is - if it's a hose, then it should be a simple and inexpensive fix. If it's a split / corroded intercooler, then it may be worth taking the unit to a rad repair place for a quote, as I think a new one is over 200£.
    Swirl bar - plenty of info about inexpensive DIY repairs on here.
    Do a bit more searching and have a read through the relevent 'sticky' threads and you should be able to save a decent chunk of change mate
    Aug 2011
    salisbury
    StatsVehicle Info
    Thank you all for ya advice off to halfords l8r to try crack into some of these repairs
    Aug 2011
    salisbury
    StatsVehicle Info
    halfords didnt have the tool but camberly auto factors did it was really easy with the correct tool thank you pls check http://www.vectra-c.com/forum/showth...39#post1615839 for my current issues and plans
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda sensor
    By danno91 in forum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:35
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
