Results 1 to 10 of 19
Thread: CD30 not working...at all?
    Aug 2011
    Horsham
    Question CD30 not working...at all?
    Hope someone here will be able to assist. I have just become the proud owner of an 06 plate Vectra SRI CDTI. I'm loving it!
    The ONLY issue I have with it is the radio/ cd/ settings control panel does not work, the info screen above it and the aircon system below work. This led me to believe it maybe a simple fuse change, so I looked in the manual and no fuse says "radio" so my questions are-
    1) Which fuse could it be?
    2) If not fuse what else may it be?
    Your help would be much appreciated.
    6 Post(s)
    IIRC, the fuse will be called infotainment system rather than radio or stereo and the fuse will be in the dashboard fusebox.
    Aug 2011
    Horsham
    Thank you, I thought that the infotainment refered to the top screen which is working fine. i will check the fuses later. thank you.
    6 Post(s)
    Quote Originally Posted by ilesal View Post
    No, there is a separate fuse for that called "instruments/information display".
    Regular Member Robsey's Avatar
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Fuses for the head unit should be Fuse 1 at the end of the dash.
    (Note there is also a 15 amp mini fuse in the back of the head-unit itself.)
    Fuse for the display is Fuse 26 at the end of the dash.
    All other fuses are via the CIM or BCM..
    Fuses are Fuse 7 and / or 9 For BCM
    Fuse 10 for CIM although the dials / clocks would be affected.
    Fuse 12 is for BCM although interior lighting would be affected.
    Fuses 17 and 19 For BCM.
    If it is just the head unit, then I would check fuse 1.
    Aug 2011
    Horsham
    I have checked fuse 1, no issue, maybe it's the fuse behind the unit. I am guessing I have to get a special removal kit. Thank you for your help.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    U just need a set of removal keys bud somewhere like Halfords etc
    North East Cheshire
    Trim : Energy
    Mileage : 101,000
    Make sure you ask for "Double Din" size..
    I know it is obvious, but just incase you didn't know..
    I used four small allen keys or long pop-rivets... does the same job..
    as long as the sticks / rods / whatever you use are no bigger than 3.3 mm or 1/8" diameter.
    Aug 2011
    Horsham
    Okay, removed it to find no issue with the fuse in the unit. What else could it be? I have a clock out by 3hrs and a radio/ cd player I can not use. Guessing it's a vauxhall dealer job?
    Regular Member Geo77's Avatar
    Sep 2009
    North Yorkshire
    Dissconnect the battery overnight. This forces a full reset of the infotainment system.
    Worth a try before dealers!
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. CD30 dead parrot working?
    By Speck in forum Electrical & ICE (including SatNav)
    Last Post: 3rd June 2012, 00:51
  4. CD30 Head Unit Not Working
    By CGSRI in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2009, 08:43
  5. cd30 not working
    By preacherman100 in forum Electrical & ICE (including SatNav)
    Last Post: 9th May 2008, 07:45
cd30 mp3 radio not working
vectra c cd30 display not working
blaupunkt cd30 front button not working
blaupunkt cd30 mp3 trouble
astra cd30 not working
cd30 radio just stopped working
vauxhall astra stereo no power
direct replacement for a blaupunkt CD30 infotainment system
opel cd30 mp3 not working
vectra cd30 not working
blaupunkt cd30 trouble
cd30 mp3 switching off
fuse for clock radio in vauxhall insignia
cd30 fuse
cd30 cd player not working
vauxhall cd30 problems
cd30 opel doesnt work
cd30 player does not wwwork
what is fuse for in back of cd30 mp3
cd30 mp3 motherboard fuses
cd30 radio fuse
Vauxhall vectra radio not working
cd30 non responsive radio
cd30 radio not responding
cd30 mp3 no power
