Results 1 to 3 of 3
Thread: Autotrader
    Jul 2011
    Durham
    Engine : 1.9 CDTi 150
    Year : 07
    Default Autotrader
    Don't know if this has been covered before but I couldn't find anything through searching.
    Looking on Autotrader it shows the 0-60 times as 9.7 seconds for the 2.2 Direct and 9.1 for the 2.0T. Is this correct?
    Just been reading through threads as I'm still dubious whether to buy the 2.2 rather than the 2.0T and in quite a lot of these threads it shows the the 2.2 0-60 as 8.7 and the 2.0T as 8.1.
    Any help?
    P.S, is the mpg much different in the 2.2 and 2.0T? As it only shows a difference of 4.9 average?
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Vauxhall brochure says manual gearbox 2.2 direct, 0 - 60 8.6. 2.0T, 8.1.
    Economy 2.2 37.7 on up to 18 inch wheel size, 2.0T 32.8 up to 18 inch wheel size.
    Regular Member Paul_NI's Avatar
    Mar 2011
    Northern Ireland
    be careful with the 2.2 you will read stories on here, including mine about issues with Fuel Pressure Regulator (~£90), High Pressure Fuel Pump (~£300) and inlet manifold Swirl Flaps (upto £600).
    The regulator is currently being replaced under a recall, but if like mine the new FPR seems to have caused my Siemens high pressure pump to have failed, which I have renewed with a new Continental high pressure pump.
    However, I do regularly get 39.2 mpg out of the car and on a whole, the car is pretty good and smooth
    Not sure what the main issues with the 2.0T are but I believe it is based on the Saab engine so should be better reliability than the 2.2 Direct.
    Paul.
  1. Autotrader Ads
    By Aidi in forum General Motoring Chat
    Last Post: 12th November 2012, 09:58
  2. Vxr on autotrader
    By PANDY 3.2 V6 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2012, 11:15
  3. anywhere other than Autotrader?..
    By chewy71 in forum General Motoring Chat
    Last Post: 8th January 2012, 22:42
  4. E-bay vs Autotrader
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2011, 17:25
  5. AutoTrader
    By si_hoss in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 13:30
