Results 1 to 10 of 22
Thread: Air Con Fault ... cost £463 !!!
    Regular Member kev.whitehead's Avatar
    Jan 2010
    Rochdale
    Angry Air Con Fault ... cost £463 !!!
    I had the aircon topped up a few weeks ago and it only seemed to work for a few days, then started just giving out 'cool' air .... so straight back to my local garage with it.
    They found, after doing a pressure test and not the original vacuum test, that the condensor rad was leaking. In fact, it had 2 small stones embedded in it!! The grill under the number plate has quite large holes in it, and so stones and other small'ish bits can go straight through and damage the condensor!! I think some mesh type of grill is in order now.
    £278 for the condensor rad, £90 for the gas service (again), and £94 labour !
    And on top off all that, the engine light has come on showing a EGR fault ... arghh!!!!
    Sep 2010
    hmmmm... bet this is what mine has!!! Mine drains after 4 weeks.
    Aug 2010
    Leeds
    They can be repaired at a radiator specialist, about £50.00 for 2x small holes.
    Yes the mesh grill is a good idea it's been discussed before.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    That seems expensive for the condensor!!
    and as for the mesh, what sort of mesh would be suitable and how would it be fitted??
    Just that my Dad's Elite has just gone in for a new condensor and we discussed fitting mesh behind the lower grille to solve the stone damage issue.
    Administrator plasma's Avatar
    On the Forum
    404 Post(s)
    Engine : 150
    Mileage : 74000
    condenser rad for these cars are no more than £120 and thats an OEM part
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    There's a 'how 2' guide on here I think to change the a/c condenser yourself too. See if you can dig it out and save yourself a lot of money!
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by plasma View Post
    Yeah, that's what it's costing us.
    Regular Member Bullylad's Avatar
    Bolton
    I had to have my rad replaced last year and then they said it was a common fault for stones to damage it.
    Common fault or design fault?
    Iv never had a problem with any other air con system on any other car regardless of age or miles. Still had to stump ur the reddies tho?
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    I just paid £108 for a new one with 2 year warranty and fitted it myself, then took it to the dealers for a regas and two tyres ballanced for £40
    Bristol
    I had a new condenser put in mine last year for £150 fitted.
  1. Replies: 15
    Last Post: 9th July 2011, 22:19
  2. What would they cost?????
    By Badger59 in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2010, 01:29
  3. How much does it cost?
    By Gortreck in forum General Chat
    Last Post: 25th July 2010, 20:04
  4. wot will it cost?
    By slow-poke in forum Engine & Drivetrain
    Last Post: 27th July 2009, 18:25
  5. what should it cost
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2006, 09:28
