Results 1 to 10 of 11
Thread: Horn is rubbish, 04 1.9cdti
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    Thumbs down Horn is rubbish, 04 1.9cdti
    Morning,
    Hopefully a quick one, I got cut up last night, hit my horn to hear the sooty and sweep van horn sound emit from somewhere under by bonnet.
    Has anyone upgraded these, if I do this will it just be plug and play? Or will I need a Tech2 or OPCOM session to match this in?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Most likely yours is just fitted with a single horn, on the passenger side, behind the bumper, under the headlight. You can get the other side pretty cheaply off ebay and its just a case of removing the bumper, bolting it on and inserting the plug that should already be there. Check which one you already have, should be 500hz I think, its then the 400hz one you need.
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    It's certainly only a single horn, but will check under the bonnet tonight to make sure it is not twin horn and failing to work.
    After that a search on Ebay....
    If I decide to fit aftermarket (non OE) will i need to map them in or will they just plug and play?
    11 Post(s)
    Quote Originally Posted by mcpitman View Post
    Unlikely you'll see anything unless you remove the front bumper.
    West
    It will be a straightforward plug & play, it was on my previous 53plate
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    The existing horn plugs might not fit after market ones......I ordered a set of VXl twin tones for our Vectra c Facelift 1.8 Z18XE Club - ones that were supposedly for the Vectra C - the sockets on the body of the Horns supplied were different.....so be aware!!!!
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    yeah mines a single horn and it sounds gay... i press the horn and it says.
    PEEP PEEP LOVE... PEEP PEEP...
    think i need a twin horn setup
    al.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    pmsl, following with interest, first time I used mine I wondered if they were working.
    I want somehing that says "GET OUT OF MY WAY", not "please, would you mind, if it's not too much trouble..."
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    To fit aftermarket ones you'll need to remove the bumper, splice into the loom, make up a small loom with electrical connectors, solder the new loom into the old loom, mount the horns, and if you have front foglights you'll need to mount one of the horns on the other side as there is only room for one as the orgional one sits just above the foglight. Much easier just to fit VX ones to the other side as its plug and play. Whip the bumper off, its dead easy.
    Heres pics of what you should fine and what your looking for when you take the bumper off. First pic is of the horn you will have, and the second pic the connector your looking for and the nut you remove to mount the second one. Youll actually need to get 2 horns, and remove the original one, to get a good horn sound, ill link you to eBay for that.
    http://www.ebay.co.uk/itm/VAUXHALL-V...1#ht_500wt_715
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    I bought a pair from E-bay.. any twin horns from a vauxhall will fit.. Astra-G, Astra-H, Vectra-B
    or Omega-B (the ones I fitted to the wife's Vectra-C)
    Sounds Goood now
  1. why is my t/c rubbish
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 23:46
  2. its just getting rubbish now!
    By twaiter in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2010, 12:35
  3. looks like rubbish....but
    By Wolflinn in forum Detailing and Car Care Discussion
    Last Post: 22nd November 2010, 00:39
  4. OK, since I'm rubbish....
    By davedrinks in forum Introduce yourself.
    Last Post: 11th October 2010, 18:42
  5. Rubbish or ok ?
    By Impresss in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2009, 12:44
front horn removal on a vectra c
