Thread: Rear left wheel knocks when drop in a hole
    Regular Member swet's Avatar
    Silistra
    Default Rear left wheel knocks when drop in a hole
    Hi guys I have a strange noise in left rear wheel when the car hit a bump or a hole in the road.I hear the sound like something knocks in the bottom of the body.I have changed the pads and the wishbones too.Any ideas?
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    Broken shock more than likely, suffering the smae noise, had the car serviced yesterday and was handed a lovely quote for £80 + Vat + labour to replace!
    Silistra
    Thank you for the fast response but I doubt about a broken shock, cause the car stands very stable in turns.I'll check it nevertheless.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Upper control arm bushes knackered id say. With the car on teh ground grab the top of the wheel behind the rear of the tyre and pull back and forth. If you hear a knockign noise 9/10 times its the upper control arm thats away.
    Silistra
    It really knocks in there.Thank you a lot for suggestion but I have no idea what "Upper control arm bushing" looks like and where it lies?
    Mar 2011
    Warrenpoint, NI
    My handling hasnt been affected either but the mechanic said its bust and leaking oil.
    Silistra
    I googled the "Upper control arm bushing"and I found it's equal to wishbone which I changet several months ago...so I don't know what to think?I'll check the shock absorber as well
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Wishbones are different to Upper control arms, most on here call them banana arms.
    these.
    http://www.ebay.co.uk/itm/VECTRA-C-R...item27b9e1e66d
    Engine : 1.9 CDTi
    Sounds like the same noise I had and mine was the upper control arms (Also known as banana arms).
    With the car parked grab the top of the wheel/tyre and pull/yank as hard as you can and see if the top of the wheel pulls outward.
  1. Other than rear upper arms and arbs what else knocks?
    By MCD in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2013, 18:15
  2. Rear wiper hole
    By carl bear in forum Bodywork & Interior
    Last Post: 23rd April 2009, 15:01
  3. Loud knocking from Left Rear Wheel
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 18:46
  4. Rear end knocks
    By Craigmill in forum Suspension, Wheels & Brakes
    Last Post: 1st March 2007, 22:12
