Thread: water leak Signum
    Jun 2011
    Leicester
    Smile water leak Signum
    Donít know if this has been posted before;
    Today found water leak inside Signum Lots of head scratching, carpet removing etc, eventually found that the drain hole under the pollen filter was blocked allowing rain water to enter the car.
    Cleaned expect this to cure issue
    Regular Member Keif's Avatar
    In the Garage
    Huge thread on here somewhere.
    Don't clean it out, remove it. It'll never block again!
    Jul 2009
    Brighton
    I was told this type of drain plug was to stop rodents climbing up and getting into your car (chewing through the pollen filter etc). Not sure if there's any truth in it, but unless you live in the sticks, you should be fine.
    But as said above, massive thread on this. Check your blower fan works in all speeds as this is one subsequent fault of water getting in.
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    31 Post(s)
    Engine : 1.9 DTH
    DHobbs ur inbox is set not to received messages so I cannot reply mate ......
  1. Water leak!
    By daddy5times in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2013, 17:14
  2. Water Leak
    By Chris SRi in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 21:43
  3. water leak
    By leesri in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 19:50
  4. water leak
    By blackcountryroy in forum Engine & Drivetrain
    Last Post: 28th January 2010, 05:59
  5. water leak
    By zubs187 in forum Engine & Drivetrain
    Last Post: 22nd July 2007, 18:17
