Thread: water in my car help needed
    May 2011
    tidworth
    Default water in my car help needed
    hi all got a problem my passenger foot well is like a sponge withlots af water and all under the plastic cover dose any one know what this could ist going to the garage on tuesday im after some info to see what it could be
    north east
    lift the skuttle panel and clean out the drain hole tube.
    you can do it with out lifting it if you dont mind getting wet, lift the bonnet, reaf firewall you will see a 2 " rubber tube, try squeezing the sides first to make it round you may get lucky and the blockage may fall out, if nut stick your fingers up it and clear out what you can.
    Woodbridge
    You may have blown the resistor in the heater so may sure you check your heaters.
    Regular Member stm's Avatar
    Oct 2007
    scotland
    Check your heater if it only blows cold your heater matrix has is burst it under the dash and will leek into the foot well
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    As Roswell mentioned the blocked scuttle drain is an absolute classic and really needs checking say once a month to pretty much ensure a dry passenger footwell carpet.
    There is bound to be a how2 on this one but it really is just a matter of bonnet up, pull up the rubber strip on the firewall at the base of the windscreen (passenger side), carefully ease up the 'flap' section of scuttle and below is the drain area and the cabin air intake and pollen filter.
    Straight down in the drain area there is a rubber bung/grommet that tends to get blocked by crap.... reach in and poke it clear... watch any water drain onto your toes.
    Once the drain has been cleared you may want to wash it out with a hose or similar. The pollen filter will need replacing - it's held in by two clips, one at the top of each side - be careful they are easy to snap off.
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Loads of threads about this, Make sure you search first before posting
    Irmscher Insignia CDTI 130
  1. Replies: 29
    Last Post: 25th July 2012, 22:52
  2. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  3. Replies: 5
    Last Post: 7th December 2010, 21:48
  4. Advice/Info Needed - Losing Water/Coolant
    By ChrisBilly in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2009, 18:20
  5. 2.0 DTi oil in water
    By nigelsanderson in forum Engine & Drivetrain
    Last Post: 14th April 2008, 11:32
