Results 1 to 10 of 20
Thread: Help needed with juddering beween 2-3k reves
    Jun 2011
    Nottingham
    Default Help needed with juddering beween 2-3k reves
    After getting juddering start on the car around 2 weeks ago I had my egr valve off yesterday and gave it a good clean before my holiday trip today, all i can say is that the valve isnt the problem, pulling my van today between 2-3k revs its as if the car is misfiring, I don't have any lights come on the dash so will struggle to get it on the diagnostics for a code reading, any advice where i can start looking for the problem would be very helpfull.
    It's the cdti 120 if that helps, I have notice that the turbo is very loud and i get a nose of air dumping when I let the gas off?
    Aug 2010
    Leeds
    Check intercooler pipe for splits and all hoses & that egr may be best to replace.
    Aug 2011
    salisbury
    I noticed that my turbo was doing the same yesterday after I cleaned my boost sensor egr is nxt on mine to be cleaned once i work out what to do, but I best check the intercooler pipe like bigtee suggests , I'm also waiting for a new lambda sensor to come as mine is faulty, looks like my swirl valves are shot to, I'm starting to regret buying my veccy only had it a little over a month I hope you get yours sorted please let me know what the problem ends up being it may help me
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    65 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved !
    Irmscher Insignia CDTI 130
    Regular Member Innes's Avatar
    Plymouth
    I had this once with a duff 3rd party MAF.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the 3rd injector wiring to me. Whether this ultimate affects 120's I don't know 100% but I think I remember reading about it on them. Either way I would look into this if I were you.
    Jun 2011
    Nottingham
    Quote Originally Posted by Gazza4 View Post
    Ok thanks Gazza4 can you tell me a bit more about the injector wiring what is the problem with them so i can lookin to it more! Don't know that much about the car yet only had it a few months, i will be checking all pipe over the weekend for cracks/leaks so may as well look at the objectors too.
    I'm also in to minds weather to put a new egr valve on it but at £120 the money may be better spent on something else like injectors or turbo if it turns out to be one of them that's shoot!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The EGR valve will give a judder and hesitation but usually at 2,000rpm and they are known to cause a 'misfire' at the range you say. When you say judder I'm under the impression it's a light shake. The 3rd injector plug will go dirty (this is only apparent if you unplug it) this can cause the problem you describe. Like I say get this checked out on here - if anyone has deffo had an issue with it on the CDTI 120.
    The EGR valve could be sticking too.
    Jun 2011
    Nottingham
    Its best described a jerking as if its holding back on boost, the egr was a bit sticky but seemed fine after i cleaned and oiled it, been out in it today and all seemed fine untill I hit 2k in 3rd gear, been reading the thread on the injectors but seems to be the 150 mainly.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    If you unplug the connector from the EGR does the jerking go away?
    You will get the Spanner light on the dashboard if you disconnect the EGR, but you should be OK.
    Does sound more like EGR to me. On mine 1500-2000k in 3rd gear always shows up first then it gradually gets worse to all gears in this rev range.
    When you say you cleaned it did you dismantle it and clean/regrease the solenoid pin?? Or did you just remove all the black stuff from in the metal housing?
  1. juddering
    By scottsabs in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 12:59
  2. Juddering?
    By ADAM123 in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2011, 21:09
  3. v6 juddering
    By jasv6 in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 21:13
  4. Help needed with 1.9cdti 150 juddering!!!!
    By stuart813 in forum Engine & Drivetrain
    Last Post: 26th May 2010, 22:36
  5. Juddering
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 26th April 2010, 22:17
