Thread: Fitted a Oil Catch Tank for DTI
    Regular Member Innes's Avatar
    Plymouth
    Default Fitted a Oil Catch Tank for DTI
    After recently doing my Inlet Manfold clean with Vectra Forever I decided that there must be a way to reduce the amount of soot and oil mixing in the Manifold. Thanks to VF he semi-blanked my EGR. The next step was to reduce the amount of oil vapour going in there so after seeing a few threads about catch tanks but none for the DTI i'd give it a go.
    Space for the tank was the main issue. I found the best place was on the battery box and as low as I could get it. Ideally it needs to be lower than the outlet on the rocker cover so if the oil condenses in the silicone hose then it'll run into the tank. I've attached the tanks with 2x 6mm bolts and wing nuts so can easily be removed for draining.
    For the returning ventilation I ran a silicone hose from the catch tank up to the coolant expansion tank and across the bulk head to the induction pipe just before the turbo. I may have to put a heat shield/sleeve over the hose as it gets warm there. its working tolerance is up to 180c so will see how it goes with out but will keep an eye on it. I ran this hose high so if any vapour left can condese and run back down into the catch tank. I thought about venting to atmosphere but as this was an MOT failiure I decided not to.
    I bought a couple of 25-16mm reducers with 90 and 45 degree bends to replace the existing brather pipe that was there.I also bought a couple of 90degree joiners. Ideally these would have been silicone ones with a bit of bend in them as the hard plastic ones I have used go 90 degrees quite abrubtly. I'll see how they go and change them if needs be. I also got 3 meters of 16mm silcone hose (not reinforced so it'll flex) and a bag of jubilee clips. The catch tanks was £25 off ebay.
    Here are a few pics.
    Jun 2011
    west mids
    looks spot on bud
    West
    nice work
    Plymouth
    2000 miles later thought I'd have a look in the tank and see how much it was catching:
    The dirty connector on the left is the IN and the clean one on the right is OUT. The out is pretty clean and I check the connector further up the hose and it was fairly clean with some oil.
    So it does seem to be catching some oil but there is still some getting through. I'll put some metal scourers in the tank for the fumes to condense on.
  1. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  2. Who has an oil catch tank fitted?
    By lee gsi in forum Diesel Engine related
    Last Post: 22nd January 2012, 13:24
  3. Oil catch tank
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2011, 16:04
  4. Just Fitted Oil Catch Tank (couple of pics)
    By john506 in forum Diesel Engine related
    Last Post: 7th September 2011, 10:17
  5. Oil catch tank 2
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 30th May 2010, 20:52
