Thread: Vectra SRi C alarm keeps going off code error fault
    Mar 2011
    Larkhall
    Question Vectra SRi C alarm keeps going off code error fault
    57 plate. Alarm has randomly been going off, got a mate to check for a fault or error code and the following showed up. But we're not sure how to sort it without putting into a garage.
    1. rear right door switch circuit open or high voltage
    2. rear right door low current
    3. power sounder datalink circuit low voltage no communication with alarm siren powersounder malfunction
    4. Inadvertant load circuit low voltage or interior light cut off circuit malfunction or instrument dimming LED output circuit
    Any ideas for fixing or will I have to drop it into a Vauxhall garage?
    Also, are the alarm sensors on the doors, bonnet and rear visible? If so what should I be looking for and where are they? had a look but can't really see anything obvious.
    Jul 2011
    hamilton
    alright mate when u checked the fault descriptions is there any codes ?????
    the door pin switches are built into the latches so u wont c them
    Mar 2011
    Larkhall
    Nah, stupidly didn't write down the codes. But it's definitely issue with the rear right door lock as contacted Vauxhall and had it in for an inspection. Vauxhall have recommended that I get it replaced for supply/fit £148.
    Mar 2011
    Larkhall
    Is the above a decent price?
    Was thinking of just buying lock and fitting myself, seen a guide in the how to section anyone done that before or as usual is it best to leave to the pros?
    Assuming this is what I would need to buy (I know that this one is wrong side)
  1. FAULT CODE HELP: p0380-08 glow device general error
    By merikiito in forum Engine & Drivetrain
    Last Post: 19th November 2011, 17:28
  2. Fault code - alarm
    By zafira in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2011, 13:07
  3. Spanner light; error code 'Preheat delay fault'
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 24th April 2009, 16:33
  4. error/fault code
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2008, 14:51
  5. Fault/Error code - misfire on cyl 1, 3 & 5
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 20:44
vectra c alarm keeps going off
2008 vauxhall vectra alarm keeps going off
why would a vectra alarm keep going off
2006 Sri vectra alarm keeps going offvauxhall vectra 2007 alarm keeps going offvauxhall astra sri alarms and service erroropel corsa c 2007 alarm troubleshootingvauxhall vectra c alarm codevauxhall vectra 08 alarm keeps going off vauxhall vectra alarm keeps going offvectra c alarm siren locationvectra c alarm codes2005 vauxhall vectra alarm keeps going offvectra alarm error codes
