Thread: smoke from cat on startup
    Jul 2011
    retford
    Default smoke from cat on startup
    guys, on startup idle theres smoke coming from the exhaust which looks like unburnt fuel, and i looked under the car today and theres smoke coming from the mesh looking part of the cat.....
    any ideas, ive seen a issue with this before but cant seem to find it
    cheers
    Jul 2011
    retford
    is it likely to be the flexi joint gone on the exhaust?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Yes very common. Custom exhaust place should be able to sort it for you for £80.
    Jul 2011
    retford
    what size is the flexi joint?
    also would this cause smoke out of the exhaust?
    mij do uni flexi joints so i may go for that if i can get the right size
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Don't know the size for sure but 52mm or 56mm seems to ring a bell.
    As for smoke what colour is it? You say unburn't fuel but is that what you smell or what you think you see? Think I had that with mine. It came out from underneath the car at the drivers door. Was coming from the bust flexi.
  1. Little puff of Blue smoke on startup...
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 13th August 2012, 11:06
  2. SRI CDTI 150 Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 15th February 2011, 13:47
  3. SRI CDTI Blue smoke on startup
    Last Post: 8th February 2011, 12:01
  4. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
  5. White/blue smoke at startup
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 27th March 2008, 08:57
