Results 1 to 10 of 14
Thread: 3.0 cdti dpf or not?
    Default 3.0 cdti dpf or not?
    A friend is looking at a 56 plate elite hatch 3.0 v6 cdti manual (z30dt). Now will it have a dpf as it's not an auto/estate/signum?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    A mate from Germany has recently removed the DPF from his Vectra Z30DT (hatch). Could be different in the UK.
    All Z30DT have DPF as far as I am aware (one of the reasons why I went for a slightly older Vectra C)
    On the Y30DT it was just the estate
    So it more than likely has one then
    Jun 2011
    Elland
    if it's a facelift, yes
    Bristol
    All facelift car have the DPF fitted.
    Jun 2011
    Elland
    Quote Originally Posted by Celes View Post
    Do you know if he just removed it (and it's still going through regen cycles), or has he managed to stop it regenning?
    At some point, I will have to replace the exhaust, as the back boxes are starting to corrode (not blowing yet, but...) and my tail pipes are sooty - they were always 'new metal' clean, so I think the DPF has started to disintegrate.
    I don't have a problem with having a DPF and regens if it is doing some good... but if I'm throwing half a gallon of diesel in the bin every 300 miles to clean a broken filter... seems a bit pointless to keep it
    I don't get any visible smoke at all, so reckon I should be good for the emissions test without a DPF - besides, there are plenty of Euro4 1.9s without DPFs and they only measure smoke opacity... Sorry, not rubbing it in with your smoking Y30 issues, maybe you should have bought a trailer and dragged a thousand litres of diesel back from Germany on your way home, mate
    Quote Originally Posted by sb1uk View Post
    Hmmmm not sure the hatch 1.9 does
    Thanks all, looks like the consensus is it will have one.
    Think the PR is referring to the 2006 onwards 3.0 V6 CDTI, and not all engines
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    @Hebblemarine,
    Elite remaps in Leeds may be able to code the DPF out, I asked around on some of the mapping forums and was told to try them. They should be able to do the EGR also.
    Yep, all Z30DT based cars will have the DPF as standard.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
vectra 3.0 cdti dpf
czy vectra 3.0 v6 cdti 2006 does have dpf
vauxhall v6 dpf removal
vectra 3.0 cdti dpf removal
signum no dpf
Vectra cdti 150 dpf or no dpf
does my 2005 3.0 v6 signum have a dpf
vauxhall signum 3.0 v6 dpf delete
