Results 1 to 10 of 13
Thread: Current issues
    Aug 2011
    salisbury
    Default Current issues
    Right my 2004 1.9 cdti sxi veccy is playing up I know I need to replace lambda sensor but I'm still waiting for the part but I need to know if what I'm experiencing could be something else
    Lots of White smoke when accelerating at a normal pace
    Black smoke when accelerating hard
    Black smoke when parked and rev hard (not alot tho)
    Trying to sit 30,40,50mph car shudders as if it's not getting enough fuel
    Accasional spanner light (diognostic says lambda sensor)
    Turbo seems to kick in about 2000 revs maybe slightly earlier car feels fairly responsive not as much as my 1.8t a4 used to but I put that down to it being a diesel
    I currently planning on replacing lambda sensor cleaning turbo sensor as on one of how 2's on this site, and I will be buying a diognostic tool of some sort
    Reading throu these forums have got me slightly paranoid about bigger more costly jobs all help and advice welcome
    Jul 2011
    wales
    Is your swirl bar still connected? I was having similar issues with juddering, maybe worth a look
    Aug 2011
    salisbury
    Quote Originally Posted by srinav View Post
    I havnt checked I'm having a day of car cleaning and dismantling more off the Audi 2morro so I'll check then
    Aug 2011
    salisbury
    Also any idea what I'm looking for on this can't seem to find a how to on it
    Aug 2011
    salisbury
    Found the link I needed I'll take a look now http://www.vectra-c.com/forum/showthread.php?t=45975
    Aug 2011
    salisbury
    Right the whole area seems gunked up I'll take pictures in a sec I can't seem to move the rod at all and I really wish I knew what I was doing can some1 please help
    Aug 2011
    salisbury
    from left to right cant really see forth
    Aug 2011
    salisbury
    cleaned the boost sensor 2day b4 and after will follow when i can work out y i cant attach
    Aug 2011
    salisbury
    Bump
    Aug 2011
    salisbury
    Quote Originally Posted by danno91 View Post
    update time
    boost sensor clean (upped my acceleration)
    replaced lambda sensor (no difference noticed)
    current symptons
    juddering at 2000rpm
    alot of black smoke when accelerating hard
    alot of black smoke while giving gas when idle
    turbo sounds loud and sounds like there is a leak when i let off gas
    current plans
    look more into swirl valves pictures above
    look into injector wires
    look for inter cooler pipe leak
    clean egr
    any advice is more then welcome
  1. List of current issues!
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 21:26
  2. My current set up...
    By danBoy in forum ICE Gallery
    Last Post: 4th July 2009, 12:26
  3. My current pet hate.....
    By AndrewTi in forum The 'Off Topic' room
    Last Post: 29th August 2008, 09:07
  4. My car in its current state...
    By danBoy in forum Quick Photo Album
    Last Post: 27th August 2007, 21:20
1.9 cdti white smoke lambda sensor
