Results 1 to 3 of 3
Thread: Water pump or thermostat?
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Default Water pump or thermostat?
    Evening all,
    The problem is that the car coolant gets to over 100deg pretty fast, the fans come on and the coolant isn't flowing back into the header tank. The heaters are also only blowing cold.
    What do you think it could be - Thermostat, water pump or both?
    The car is on 140K and had the pump last changed with the cambelt etc at 80K. The thermostat is the original.
    Thanks,
    Steve.
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by ghostrider View Post
    Coolant will always get back to the expansion tank even if the thermostat failed closed as there is a bypass pipe which allows it circulate until the thermostat opens. Sounds like the pump has failed. Check the bottom hose return from the radiator when the fans kick in, if its still cold id nearly put money on a failed pump.
    On another planet
    Engine : 2.0
    Thanks for the reply Yes it is cold
    Oh well, that's tommorow sitting in the house watching daytime TV then! I may as well get drunk tonight then as i'll be going nowhere tommorow
    I'll call the AA out on Tuesday morning then, as i guess i shouldn't drive it in case it fails dramaticlly and takes the cam belt out.
    Many thanks for your help DasArab.
  1. Water pump 1.9
    By Kramel in forum Engine & Drivetrain
    Last Post: 15th July 2012, 12:12
  2. Water pump help
    By SeanRyan in forum Engine & Drivetrain
    Last Post: 24th September 2011, 14:55
  3. water pump
    By bigcraig in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2008, 19:50
  4. Water pump
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 17th February 2008, 10:07
  5. is this the water pump??
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 6th February 2008, 00:00
