Thread: Windscreen wiper problems
    Aug 2011
    Glasgow
    Default Windscreen wiper problems
    Hi guys , I am having a prolem with my front windscreen wipers ; they park vertically and is a blocking a bit of my view .
    Could anyone please advise ??
    Cheers guys
    Kenny
    Essex
    Any other issues with them? Probably need a new wiper motor.
    Regular Member Jezzy's Avatar
    S.E
    Does the windscreen washer system still work?
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    I had the same about a year ago. It was the motor and I replaced it myself thanks to the how2's on here.
    manchester
    mine are doing exactly the same,everything else is working fine,washers wiper speeds there just parking in the middle of the screen you can get them to park properly when you have switched the engine off.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I had the same problem, I had fitted a set of flat wipers that had a little 'ramp' on the top to press them to the windscreen; it had been a little windy and I had been travelling on the motorway.
    I fixed mine by removing the wiper arms, removing the rubber edging from the panel under the windscreen, slightly lifting the trim panel and then loosening/retightening the nut on the top of the motor connection.
    The short of it was that the increased pressure cause the nut to loosen and then tighten again afterwards when the wipers were vertical. I also changed to standard wipers
  1. windscreen wiper problem
    By dean79 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2011, 20:05
  2. Windscreen wiper dead
    By Nicolas in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2009, 23:08
  3. Windscreen wiper probs
    By orcha173 in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2008, 20:27
  4. Windscreen wiper failure
    By Hideous in forum Bodywork & Interior
    Last Post: 23rd January 2008, 17:00
front windiw wiper motor for vectra c cdti 3.0.v6
