Thread: strange warning light
    Regular Member chrissri82's Avatar
    Apr 2009
    airdrie
    Default strange warning light
    got an unusual warning light this morn. looks like a building with a chimney the right side with a jagged line going through the middle. yellow at bottom and black above the line. it doesnt light up when you turn ignition key and i cant find the book to answer this myself. checked my sister astra book and this doesnt help either.
    any ideas would be much appreciated.
    thanks
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Sounds like the "Coolant Level" warning light, you might just need to top up your water..
    Apr 2009
    airdrie
    Quote Originally Posted by nibblitz View Post
    thanks mate, hope thats all. just never seen light before and coolant level doesnt look to bad. that was first thing i checked.
    Chelmsford
    Yeah, that's the coolant indicator.
    Used to get that when my radiator was slowly leaking due to the standard "rust along the plastic/metal join".
    If your coolant level is consistent and ok when cool, I'd say it's likely to be a faulty sensor.
    13 Post(s)
    Quote Originally Posted by chrissri82 View Post
    http://www.vauxhall.co.uk/manuals
    or
    https://www.vauxhallproductforum.co....pid=11&cid=312
  1. Strange Warning Loght Combination....
    By Brummie in forum Engine & Drivetrain
    Last Post: 14th February 2013, 09:29
  2. Strange intermittent left fog lamp warning
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2012, 12:02
  3. strange warning light vauxhall dont no what it is
    By barrymanalow87 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2010, 20:35
  4. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
  5. 2.2 2003 Vectra Strange Warning Light Problem?
    By sophos9 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 13:16
vectra c radiator side plastic part leaking site:www.vectra-c.com
