Results 1 to 3 of 3
Thread: blown fuse?
    Regular Member paddyvectra's Avatar
    Jul 2011
    Carterton, but.....I walk a lonely road the only road i have ever known
    Default blown fuse?
    how do i find out if i blown a fuse or amp? Is there any simple test i can do?
    My aircon unit has no power going to it but all wiring is fine. Also my interior lights are no longer coming on. I did hijack onto these with some led's and thinking thats maybe what blew the fuse's how do i check them tho? I have an 08vectra estate 1.9CDTI
    Thanks in advance
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    the easiest way is with a multimeter,otherwise remove fuse a fit the next good fuse into the carrier
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Should be able to see the fuse wire has blown.
    if your going to swap fuses with something make sure it's the same amp fuse.
  1. Fuse blown, but which one?
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2012, 14:40
  2. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  3. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Vectra C / Signum Troubleshooting
    Last Post: 8th January 2011, 22:02
  4. blown fuse????
    By gaz 1982 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2007, 17:20
  5. Radio fuse blown?
    By beachlife in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2007, 19:26
