Thread: website translation help
    Oct 2006
    southampton
    15 Post(s)
    Default website translation help
    want this translated, has anyone got any good links to sites that can help me out please...
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    google translator mate
    newport
    Spacers 10 mm Opel Vectra C SP5024
    Lane drive kit fits Opel Vectra Caravan C Lim (model Vectra / Lim., From 04.02)
    Mach - me - wider! That's the motto of the CSR-Automotive Kits Spacers. In the twinkling of an eye to a heavily upgraded vehicle appearance, much better road holding and increased safety when driving through curves. CSR-Automotive Spurplattenkits for one axis are designed and tuned specifically for your vehicle type. Tracking plates of CSR-Automotive are "Made in USA" and not a cheap Chinese goods. The package includes:
    2 track plates for 10 mm track widening per axle (5 mm per side)
    suitable for vehicle type Opel Vectra Caravan C Lim (model Vectra / Lim., from 04.02)
    with PCD 5 / 110
    with centering 65.1
    Radschraubenma▀ M14x1, 5
    System 2 (Through Hole)
    Vehicle-specific T▄V parts certificate
    Applies to all CSR-Automotive track panels:
    Made of aluminum alloy, extruded and tempered
    About 60% weight savings over steel!
    Manufactured on modern CNC lathes and milling machines, meaning no additional imbalance on the axles
    Made in USA
    The Assembly is simple and follows the "Plug and Play" principle: between rim and wheel axle, the track record inserted - this ensures that the rim has a greater distance from the vehicle. For the installation of the pan, usually only about 20 minutes are required.
    How to measure:
    You need to attach a longer wheel bolts, these are not included. The standard wheel-mounted can not be used. Please note using the instructions below, which bolts you need:
    Note the above Radschraubenma▀
    Determine the length of the new wheel even in three easy steps:
    Measure the exact body length in mm of the original wheel of your car
    Add to the measured length of the track above the plate thickness in mm
    (Example: screw length 28mm + 15mm Spacers (each side) = 43mm length)
    Check if you need wheel with ball-or cone-head
    Order the necessary bolts to your lane widening the same time! There are no additional shipping costs.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    dont work lol
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    Regular Member Geo77's Avatar
    Sep 2009
    North Yorkshire
    Use the special translator
    Known as post #3
  1. Extended Translation
    By ShoG in forum Diesel Engine related
    Last Post: 12th September 2009, 07:42
  2. Lost in translation...
    By JuzzyD in forum Comedy & Humour
    Last Post: 1st November 2008, 17:02
  3. Replies: 3
    Last Post: 14th April 2008, 21:23
  4. Translation
    By CPHB in forum General Chat
    Last Post: 29th January 2007, 10:11
  5. Lost in translation
    By ed taylor in forum General Chat
    Last Post: 24th December 2006, 00:45
