Thread: Power steering help
    Aug 2011
    derby
    Default Power steering help
    car 1.9cdti 120 ps - 2004 reg
    Light came on dash regarding the power steering changed the pump after disconnecting the battery car runs fine for a bit then steering goes heavey again.
    Does the pump have to be programed into the ecu/
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Does it not just need bleeding and topping up?
    Don't think you need to program it in (might be wrong though )
    hth
    Aug 2011
    derby
    self bleeding apparently lol. The unit it brand new had it sent back and the one they sent out is new as well. It works when i disconnect the battery but then plays up again the next day
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I always bleed them with the engine ticking over, turn the steering lock-to-lock slowly a few times.
    Check the connections on the battery-to-body earth, and at the steering pump.
    Re-check the fluid level.
    Also, check the volts at the battery with the car ticking over and all electrics (blower, air con, lights, etc) off. Should be about 14.3v. If it's lower, it could be a suspect alternator, as the power steering is usually the first thing to stop working when the alternator starts to fail, as I found out!
    Aug 2011
    derby
    alternators fine apparently it does need programming in as iv done a quick search, Apparently anyone with the op-com software is able to do it provided they got the option in the drop down menu lol.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by mr.d View Post
    I learn something new every day
    Dealers charge about £75 for a Tech2 session. Think there's a section on here with a list of people in areas with Tech2 and Opcom, who are willing to help out other members
    Aug 2011
    derby
    lol i just want my dad off my case about it lol i live in derbyshire so hopefully their is someone around here lol
    Aug 2011
    derby
    tony mate im calling it a night ill search for plp wiv tech 2 on ere tomoz thanks for ur help
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    No probs mate.
    HTH
    Shropshire
    Shouldn't need programming - I had mine changed a couple of months ago, bought a second hand one of ebay, and it's fine. Stupid question, but is the new one for the same vehicle? Don't know whether that makes a difference or not?
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
vectra c power steering problems 2004 site:www.vectra-c.com
