Results 1 to 10 of 11
Thread: Any cdti owners on 2nite?????
    Jul 2011
    wales
    Default Any cdti owners on 2nite?????
    Hi guys well ive had my intake manifold done at last, juddering at 1800 revs now gone. But still have like a second turbo feel at 2200 revs anyone know what this problem is? It goes well but its like its got 2 turbos really annoying at times. Thanks in advance guys.
    Jun 2011
    Elland
    EGR? Transition between EGR open and closing...?
    Can yank the EGR plug (you will get a code thrown), drive it, if the 'problem' goes away, then consider blanking / mapping out.
    Or it could be just a characteristic of the engine /turbo - my V6 diesel seems to feel the same, only around 2000 revs, where it gets its' legs.
    You may have a couple of things happening at around this engine speed: EGR shutting off and VNT tweaking the turbo geometry when you are going from pottering around speeds to 'let's give it some'.
    Just some thoughts
    Jul 2011
    wales
    Ive tried cleaning egr on it but i didnt split it to get solenoid out but seemed to be moving freely, it doesnt do it all the time but its a little problem thats niggling at me. My dads got same car so i might try his egr and boost sensor on mine see if it still there if it is i can look elsewhere.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The jerk you feel is probably the swirl flaps opening up. Since you replaced the manfiold this will be present now. Will settle down though.
    Jul 2011
    wales
    The power jerk u mean yea? Hopefully it just needs running in then?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by srinav View Post
    Wish mine still done it. It will settle down once the EGR valve soots the manfiold up again.
    Jul 2011
    wales
    Lol thing is it was there before i had manifold done aswell but maybe that was due to the swirl bar falling off?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    It's normal anyway. The turbo spools up at 2,000rpm, and at 2,500rpm or just before (depends on how the car has been driven) the swirl valves open up fully. If the bar falls off and the valves are fully open you will get the same, but this is how the map on the ECU is set up. Other than that I don't think there is anything wrong.
    Woodbridge
    The wife has the 120 and she had a stutter at 1800 (Not sure if it is the same) but we changed the EGR and all is fine.
    Jul 2011
    wales
    Gazza thanks for your help mate appreciate it. Ginge ill try my dads egr as its the same but i think what gazza is sayin makes sense
  1. Insignia CDTI 130 owners
    By Vaux-Man-G in forum Insignia car chat
    Last Post: 25th August 2012, 07:27
  2. Sitting bored at home 2nite watching Eurovision
    By GTS in forum The 'Off Topic' room
    Last Post: 14th May 2011, 23:37
  3. spotted cormac81 in lurgan 2nite
    By EURO G in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 19th May 2008, 22:19
  4. 150 CDTI Owners help
    By leeds vectra in forum Engine & Drivetrain
    Last Post: 3rd November 2006, 11:13
