Results 1 to 10 of 11
Thread: More boost
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default More boost
    If you are fitting a hybrid turbo as I have and wish to raise the boost above the 3 bar absolute limit, it can be done quite easily by fitting a third party 3.5 sensor. I used a Zeitronix MAP sensor good for 50psi absolute.
    Best to add the sensor and remap at the same time with a place that has an external pressure sensor, so you can ensure you don't over cook it.
    spoons
    Guest
    Yes but will it now do 1/4 mile in less than 15 seconds?
    EVERYWHERE
    My (very) old Honda CBR1000 will do it in less than 11, but that seems not to be the point of the excercise.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    i recon my dads supecharged 4.2 v8 jag will prob do it under 15
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Perhaps we should have a club prize for the first sub 14 second Vec - new engine or tyres come to mind hehehe.
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I think with over 240bhp now I should be under 15 seconds.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by nutron View Post
    That's a serious amount of power. How much room is there left to play with if you have stock internals?
    Jun 2011
    Elland
    Probably not a lot... but quite a testiment to the engine: same specific power output for 3.0L would be 379hp...
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Well that was on Friday when I was running the stock 3bar sensor at its max of 29psi relative. After fitting the 3.5bar sensor, I should be running about 34psi and need to get it back on the rollers to check the exact boost and what output it is making now as I have had to turn the methanol down alot in the peak torque reagion 2500-3000rpm to prevent clutch slip.
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Can you increase the boost on a standard vectra, and is it online done via a remap, the car already has a map.
  1. No Boost/Irregular Boost
    By Seery_SRI in forum Engine & Drivetrain
    Last Post: 8th March 2011, 08:48
  2. boost flat spot boost????
    By lgtuk in forum Engine & Drivetrain
    Last Post: 7th June 2010, 16:14
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
