Results 1 to 10 of 11
Thread: handbrake return spring????
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default handbrake return spring????
    hi all, out fartin about with my car as my handbrake on the os/f sticks on. so stripped it all down and freed it up as it was siesed. but i think its all free but when you put the hand brake on and release it it still wont disengage properly.
    the spring looks ok pleanty of springyness in it if that makes sense. still feels ok.
    is this an issuse of it not being strong enough any more, or do i need to free up the mechinisim on the caliper a bit more?
    cheers in advance its doing my heed in!
    Tim
    Full Member lizard's Avatar
    Oct 2006
    southampton
    15 Post(s)
    springyness love it, wait till jezzy gets here , i have 2 spare if you need to replace it Tim...
    Nov 2010
    BRECHIN
    didnt know what else to call it lol
    it seems fine tho. does the spring have to pull the handbrake cable back thru?
    it goes 90% of the way then i need to tap it with a small hammer to relese it the rest of the way. highly annoying!
    Oct 2006
    southampton
    15 Post(s)
    are you on about the grommet that sits in the round housing of the arm or the cable actually going through the grommet, Is the grommet seated properly, seems like a binding issue, try WD40 or release handbrake grease cable, engage handbrake and do the same, then just on off on off on off the get the lubrication in, thats all i can think of matey...
    Nov 2010
    BRECHIN
    no the cable is seated correctly, its just the mechinisim where the cable connects to the caliper and there is a spring on the otherside of it to help the cable be pulled thru and return the mech to the off position.
    pulled the cable with pliers. seems to be free enough just gonna have to go and battle with more wd i think
    Oct 2006
    southampton
    15 Post(s)
    Quote Originally Posted by TimTay View Post
    May have to strip caliper down Tim, I have all the parts needed if you want, seals, seal covers, guide sleeves and caps, let me know if you need them...
    Nov 2010
    BRECHIN
    doh!
    da tell me that! lol
    well just had another looky there. now the handbrake bit on the caliper works fine with out the cable attached. doesent stick. so i am assumeing that the cable may be dry?? just a tad to tight for it to be pulled back thru fully.
    or what ever it connects to is. how easy is it to remove it from the handbrake its self?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Tim
    Hi, I had this with one of my rear calipers causing the disc to overheat - I put a second spring on and that did the trick - although I eventually I replaced the caliper. It seems to be a sealed unit with no access to the handbrake mechanism
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Did you try removing the spring on the caliper? One of mine broke a couple of weeks ago and I managed to rob a couple off a vec at the scrappys this week, were a pig to remove and put back on. Maybe as you say the tension in the spring has gone. If you can remove the spring easily id say it is gone. Off the cailper the spring is at least 15-20mm shorter than it is when stretched in place.
    New Member lexus_dave's Avatar
    Sep 2010
    sunderland
    Default recall
    try contacting the dealer and see if there is a recall for yours because mine was recalled about 3 months ago for handbrake mechanism mine is on an 03 plate
  1. Handbrake Return Spring.
    By Das in forum Suspension, Wheels & Brakes
    Last Post: 16th August 2011, 17:01
  2. Clutch Return Spring
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 14:47
  3. Gear Knob return spring?
    By design22 in forum Bodywork & Interior
    Last Post: 28th March 2011, 13:25
  4. Clutch Return spring tension
    By Dazbaz in forum Vectra C / Signum Troubleshooting
    Last Post: 20th January 2010, 12:54
  5. modified clutch return spring
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2009, 22:40
vectra c handbrake return spring
vectra c handbrake reset
vauxhall vectra handbrake return spring
how to replace a brake return spring on a vauxhall
vectra b handbrake return springs
handbrake release spring
can i replace handbrake release spring vectra c
handbrake return springs vauxhall vectra c
vectra hanbrake return spring
vectra c brake caliper spring
vectra c handbrake spring
vectra c handbreak reset
vectra 2004 handbrake return spring
