Results 1 to 10 of 11
Thread: Diognostic tool revisited
    Aug 2011
    salisbury
    Default Diognostic tool revisited
    Due to the fact that the diagnostic tools I was looking at were classed as clones my last thread was closed
    This time I'm would like help finding a diagnostic tool that is not a clone, at the same time I only want to be able to read faults I have no need to reprogram anything (and I wouldn't like to try),
    So is there any cheaper versions that just read and clear faults
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by danno91 View Post
    Hi, There are several cheap diagnostic scanners available (try Ebay) but most have very limited functions, and will not always identify faults and some will not clear them anyway - perhaps other members can advise on the better ones.
    The best system is Op Com (genuine of course!) which runs via your PC - it will do a lot of the things (but not all) GM's Tech 2 system will do. Unfortunately it costs hundreds of pounds and is not a viable option for most members. As you are aware I am not allowed to mention the other option - apparently it breaches copyright regulations and the Forum Organisers have quite properly refused to allow any mention of it on the site. Other sites will discuss it quite openly leaving the morals of it to the individual.
    Appreciate your question - its a bit galling to have to go to a dealer to be charged to have your problem diagnosed before you can even start to repair the car - but hey there you go!
    Good luck with it
    West
    Regular Member Mads's Avatar
    Ipswich,.UK
    i have one of them too from a different seller, how would you know if its cloned or not or was that a different make?
    Aug 2011
    salisbury
    Thanks for the info I dunno what is classed as clone I just know my last thread was closed so the link I put up must have been a clone
    West
    Quote Originally Posted by Mads View Post
    mine wasn't from that seller either, the seller i got mine from was in York... i just found on in uk at a reasonable price as they do vary
    the talk of cloned stuff is basically a pirate copy of a well known pc/laptop based tool which is not allowed to be discussed on the forum for legal reasons
    Ipswich,.UK
    thanks mate so the ms509's are ok then?
    Jun 2011
    Elland
    make sure your intended reader can read all types of codes. I *think* it needs to be OBD2 (OBDII) compatable. You could end up with something only able to read the 'check engine' codes from the engine ECU, whereas you want to be able to read 'spanner light' codes as well.
    Aug 2011
    salisbury
    Quote Originally Posted by hebblemarine View Post
    Yes that's the codes I currently need to read Thank you for that
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I use one of these..
    http://www.ebay.co.uk/itm/LATEST-UNI...-/110435257313
    No probs so far, and saved me money as garages charge more than the price of this to read the codes
  1. My tool box
    By marc vectra sri in forum General Chat
    Last Post: 4th July 2012, 22:12
  2. Diognostic tool
    By danno91 in forum Engine & Drivetrain
    Last Post: 26th August 2011, 13:49
  3. Park Pilot revisited
    By keefy*2010 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2010, 22:53
  4. What a tool.
    Last Post: 22nd September 2010, 11:56
  5. CDTI Swirl Valve revisited
    By chrish in forum Engine & Drivetrain
    Last Post: 26th August 2007, 11:44
